Forum: Music discussion
Topic: One deck quieter than the other? any help appriciated
Ok,
So its that time and im bringing in the mix, from where im standing its sounds fine, BUT when i listen back to the recording afterwards the main song that was playing is at a nice level and when the mix comes in the level seems to drop quite alot.
Is there a reason for this? or a way that they will be at the same volume level?
Kind Regards
Mighty
geposted Fri 16 Oct 09 @ 6:29 am
PS this is on the dj control mp3 modal.
geposted Fri 16 Oct 09 @ 6:32 am
Change your crossfader mode to FULL instead of SMOOTH. To do that, you click on the config button and look for the crossfader mode, it will be on SMOOTH from what you explained here, double click to change it to FULL and you are on...
Hope this help
geposted Thu 12 Nov 09 @ 12:34 pm
