Hi,
Anybody out there using a Mini Mac for DJing, I'm Getting Tired Of My PC.
Thanx
kk
Thanx
kk
geposted Sun 18 Oct 09 @ 1:23 pm
I think you mean Mac Mini (not Mini Mac).
geposted Mon 19 Oct 09 @ 5:51 pm
Mac Mini Yes Do use It or Do You Know Some DJ That Does?
geposted Mon 19 Oct 09 @ 6:02 pm
the problem is that you must use an external screen and for a DJ on the road is it simpler to use a Macbook(pro)
geposted Tue 20 Oct 09 @ 10:36 am
As long as the specs are up to par for a Mac Mini (i.e. it meets, but more ideally exceeds the minimum specs) for VDJ then it should be fine. Like the other guy said though, you would then have to cart around a display monitor; not too portable. Just get a Macbook (unless you're a bedroom DJ).
geposted Tue 20 Oct 09 @ 2:11 pm
If you build the box that holds the monitor with the Mac Mini in it, all Components are connected just plug it in & hook up powered speakers & your spinning. No chance of breaking wires & less time to set up. Thanx I will look into a Mac Book Pro it might be less costly. kat
geposted Tue 20 Oct 09 @ 4:24 pm
Even with a custom box it's going to be fairly cumbersome, take up a lot of table space, you won't have the option of putting it on laptop stand (like the "L-Stand"), and it wouldn't be much cheaper.
geposted Wed 21 Oct 09 @ 5:15 pm
I use a MacBook Pro - The Mac Mini should work fine. but then you need to carry a separate monitor. However, the Mac Mini is cheaper than a Mac notebook starting at 599 with the top model at 799 dollars.
geposted Wed 21 Oct 09 @ 8:55 pm
the new mac mini is very good there will be some touch screens coming out this week you can mont it at back of many of the monitors out there,you can get a mac book pro with win 7 i saw one today at the apple store with win 7
geposted Fri 23 Oct 09 @ 2:06 am
DJ Phil
Here's my next question: is the Graphics card in the Mac Mini capable of handing video's & Karaoke?
Thx for answering my Questions. What CPU Rig are you using?
kat
geposted Fri 23 Oct 09 @ 7:53 am
According to the specs I am reading on apples website the mac minis come with Nvidia GeForce 9000M with 256mb DDR3 of SDRAM Shared and Virtual DJ Requires 256mb DDR3 of dedicated memory on your graphicas card.
http://store.apple.com/us/browse/home/shop_mac/family/mac_mini?aid=AIC-NAUS-K2-CONFIGURE-MACMINI-DESIGN&cp=CONFIGURE-MACMINI-DESIGN
I have seen some Mac Minis being sold at Fry's electronics with 1gb DDR3 dedicated video memory, I remember before you could upgrade the video on mini macs on apples website but I no longer see that option.
geposted Wed 28 Oct 09 @ 3:00 pm
So does anybody know,or has any knowledge (convenient or not) if the mac mini can work well with VDJ?
geposted Sun 02 May 10 @ 11:09 am
I have an older Core 2 Duo mac mini with the intel GM945 integrated graphics chip and it works fine with the latest version of VDJ (6.0.7) or audio and video. Also works fine in bootcamp with XP.
I like the newer ones as they support 2 video outptuts (finally)
geposted Tue 04 May 10 @ 12:12 pm
Krazy Kat DJs wrote :
Hi,
Thanx
kk
Thanx
kk
Yes the Mac Mini works just fine with VDJ 8 and 7...as well as Serato DJ and Djay Pro. So sometimes I like using VDJ over Serato.DJ and Vice Versa as well as DJay Pro (OS X only). So i bought a used Mac Mini 2.1GHZ 4GB RAM 250GBSSD 250.00. So When I need it is always with me and use the Built In Monitor on my HP 14 Touchsmart Sleekbook as Monitor. 2 Different operating systems when I need it. ( it is quit costly purchasing a Macbook Pro with Windows 10 as well as OS X)
geposted Thu 17 Nov 16 @ 3:16 pm
You're replying to a question posed 7 years ago.
geposted Thu 17 Nov 16 @ 3:27 pm
