Hi, in VDJ you can link a video to a sound file by dragging the videofile to the video window.
Is it possible to add start and end point in that clip. (Cue points) I have some video's that are longer than the song and I want the video not to start from the begining.
Perhaps when you drag the video in the window a popup is give to set the beginning and end point.
Ofcourse create also a parameter in the settings of VDJ to enable/disable this popup window
Thanks
Thanks
geposted Wed 28 Oct 09 @ 4:22 pm
I kinda requested the same feature..
basically the idea was the ability to link videos/pictures to a cue point (instead of just the song)
**hippydog runs off to see if he can find his post**
found it!
found it!
geposted Thu 29 Oct 09 @ 3:28 pm
