Moin an alle,
Hab da mal ne Frage...sorry wenn sie vielleicht schon mal gestellt wurde...
Wann wird die 6.03 vermutlich bereitgestellt??
Danke schon mal!!!
Danke schon mal!!!
geposted Tue 10 Nov 09 @ 7:44 am
Schätzungsweise in ca 3 Monaten :-D
Ne, wenn alles klappt dann heute.
geposted Tue 10 Nov 09 @ 7:49 am
Sobald sie fertig ist ;-)
Da sind schon noch einige Tests zu machen.... Habt einfach noch etwas Geduld.
geposted Tue 10 Nov 09 @ 7:50 am
:-))) Scherzkeks
Vielen Dank...dann weiß man ja wenigstens bescheid!!!
geposted Tue 10 Nov 09 @ 8:01 am
Fertig. Die neue Version ist ab sofort im Download Center.
geposted Tue 10 Nov 09 @ 8:19 am
hier noch die Änderungen:
- fixed search crash
- [mac] fixed random crashes
- fixed crash on v5 skins with v6 actions
- fixed crash on reload itunes subfolder
- fixed "goto -1" to stay in sync
- fixed set_cue sometimes not saved
- fixed goto_cue and hotcue when looped to keep the loop
- open in explorer selects the file
- forced mix starts from the selected transition type's entry point
- soundconfig changes saved when switching to another tab or closing the options dialog
- fixed headphone_mix in automix
- fixed no long sort on filedate
- fixed cracks with equalizer and safemode
- fixed videos with multiple AC3 tracks
- fixed smart_scratch in reverse mode
- fixed djc_button_popup
- fixed sort in playlist reload next track if changed
- fixed click on coverflow keeps selected song in view
- fixed fade to black kept if disabled
- fixed dump can stay stucked
- fixed volume keys on keyboard for shortcuts
- fixed unicode in karaoke zip
- fixed unicode in playlist/history
- fixed unicode in broadcast infos
- fix unicode and accents in search box
- fixed case insensitive search for unicode chars
- space in search matches '-' or '_'
- [mac] fixed action learn on mapper page
- [mac] fixed drive column
- fixed CDJ400, MEP7000
- fixed stealth and omni mappers/devices
- fixed ns7 platter speed not correct
- fixed ns7 sound jumps when beattap or scrolling in songs
- fixed hercules steel definitions (right stop button)
- fixed Hercules Trim audio
- fixed Hercules RMX audio in loopback mode
- added CDJ2000, CDJ900
- search in greek and russian can use transliteration
- don't add to searchdb files that are not physically present (from itunes, history, playlists, etc)
- added timecode engine v4
- better layout in the mapper dialog
- optimized memory managment
- new action: set_gain, preview, loop_button
- new timecode debug option: smooth pitch
- new config/option: vinyl mode
- new folder context menu: create subfolder
- can drag and drop files from within virutaldj, by pressing CTRL when dropping over a folder
- soundengine quality improved in safemode
und vieles mehr. Diese sind aber nur kleinigkeiten und muss man nicht unbedingt erwähnen :-D
http://www.virtualdj.com/wiki/VirtualDJv6.0.3.html
geposted Tue 10 Nov 09 @ 8:37 am
