Forum: Greek Forum - Topic: Virtual dj 6.03, me kalyteri yposthrikski ΕΛΛΗΝΙΚΩΝ, katebaste to tora !!!
Ότι θέλετε να ρωτήσετε για το Virtual Dj και όχι μόνο,είμαστε εδώ για να το απαντήσουμε. Παρακαλώ να διαβάζετε όλα τα topics πριν δημιουργήσετε καινούρια. Αν δεν σας ανοίγει το πρόγραμμα γράψτε το εδω: : contact , ...Κανόνες.., Greek faq & Info Base, edw...
VirtualDJ Forum
Greek Forum
Virtual dj 6.03,...
Autor - Topic: Virtual dj 6.03, me kalyteri yposthrikski ΕΛΛΗΝΙΚΩΝ, katebaste to tora !!! -
apopsis
Atomix Productions
Posted Tue 10 Nov 09 @ 11:14 am
VirtualDJ 6.0.3 (9 November 2009)
Improvements:
* Windows 7 compatible [PC]
* soundengine quality improved in safemode [PC]
* can drag and drop files from within virutaldj, by pressing CTRL when dropping over a folder
* don't add to search db files that are not physically present (from itunes, history, playlists, etc)
* added timecode engine v4
* optimized memory managment
* search in greek and russian can use transliteration
* space in search matches '-' or '_'
* better layout in the mapper dialog
* new action: set_gain, preview, loop_button
* new timecode debug option: smooth pitch
* new config/option: vinyl mode
* new folder context menu: create subfolder
* open in explorer selects the file [PC]
* forced mix starts from the selected transition type's entry point
* added CDJ2000, CDJ900
Fixes:
* fixed random search crash [PC]
* fixed random graphic crashes [MAC]
* fixed crash on v5 skins with v6 actions
* fixed crash on reload itunes subfolder
* fixed pops with equalizer and safemode [PC]
* fixed videos with multiple AC3 tracks
* fixed "goto -1" to stay in sync
* fixed set_cue sometimes not saved
* fixed goto_cue and hotcue when looped to keep the loop
* fixed headphone_mix in automix
* fixed no long sort on filedate
* fixed smart_scratch in reverse mode
* fixed djc_button_popup
* fixed sort in playlist reload next track if changed
* fixed click on coverflow keeps selected song in view
* fixed fade to black kept if disabled
* fixed dump can stay stucked
* fixed volume keys on keyboard for shortcuts [PC]
* fixed unicode in karaoke zip [PC]
* fixed unicode in playlist/history [PC]
* fixed unicode in broadcast infos
* fixed unicode and accents in search box
* fixed case insensitive search for unicode chars
* fixed action learn on mapper page [MAC]
* fixed missing jogwheel sensitivity (bend) option [MAC]
* fixed backspace removes songs from playlist [MAC]
* fixed save soundconfig changes when leaving the page
* fixed drive column [MAC]
* fixed stealth and omni mappers
* fixed ns7 platter speed not correct
* fixed ns7 sound jumps when beattap or scrolling in songs
* fixed hercules steel definitions (right stop button)
* fixed Hercules Trim audio
* fixed Hercules RMX audio in loopback mode
* fixed CDJ400
*Ayta pou einai bold i kokkina einai pou ta "palepsame" apo to elliniko team o djDad kai ego.
djdad
Atomix Productions
Posted Tue 10 Nov 09 @ 5:37 pm
Na prosthesw ki egw kati oson afora to elliniko search.
Gia na ginoume pio katanoitoi, apo simera osoi exoun tragoudia (files) me ellinikous xaraktires, xairontai dipla. Giati oxi mono douleuei to ellhniko search me ellinikous xaraktires ANEKSARTITA an grafeis me mikra i kefalaia (opws akrivws ginotan mexri twra gia tous latinikous xaraktires), alla giati antistoixizei tous ellinikous me tous latinikous xaraktires.
Kai eksigoumai..
As ypothesoume oti exeis kapoia files me PARIO kapoia me Parios kapoia me Παριος και κάποια με ΠΑΡΙΟΣ.
Gr;fwntaw sta ellinika ΠΑΡΙΟΣ ή παριος ή ΠαΡιοΣ ή οπως αλλοιως θέλετε τα βρίσκει ΟΛΑ. kai to anapodo bebaia grafeis Parios PARIO kai briskei kai ta ellinika.
Yparxei omws ena mikro bug, to opoio mas ksefyge, den prolabame tin 6.03 alla tha ginei stin 6.04. Auto einai to oti den antistoixizei ta fwnienta me tono ta mikra me ta kefalaia. An dld yparxoyn files με Πάριο κι εσύ γράψεις ΠΑριος δεν θα τα βρεί. Γενικά εκεί με τους τόνους δεν δώσαμε ισως να το καταλάβουν. Αλλωστε παιδιά η γλώσσα μας είναι γι αυτούς όπως εμάς τα Κινέζικα
Episis kati gia ti nea leitourgia move files me drag n drop...
Me tin metakinisi arxeiwn me ayto ton tropo enimerwnetai automata kai i database, pou simainei oti oti leitourgies aforoun metakiniseis apo folder se folder kalo tha itan na ginontai mesa apo to VirtualDJ afou etsi glitwnoume to update tis db.
Episis prostethikan ta CDJ2000,....eytyxws giati molis eixa paraggeilei dyo !!!!!!!!!!! xaxxaxaxaxx
apopsis
Atomix Productions
Posted Wed 11 Nov 09 @ 4:29 am
O browser apo monos tou "krybei" (kai kala kanei) ta _ (underscores) pou simainei oti ena arxeio Michael_Jackson - xxxx... (pou ton thimithika..) to blepeis ston browser Michael Jackson - xxxx... (xoris ta _ )
Etsi loipon to search -mexri tin 6.02- tha eprepe na einai 100% akribes gia na sou emfanisei ola ta arxeia, an ta misa sou arxeia tou michael exoun _ kai ta alla misa oxi, tha eprepe na kaneis 2 fores search gia na ta breis ola.
To parapano fix to diorthonei ayto opos kai me tis paules... opote.. "_" kai "-" ennoountai patontas aplo space.
SIMPLE...
Oso gia ta fonienta, exei dikio o dj dad omos to problima emfanizetai otan kanoume search stin elliniki glossa.
Etsi loipon gia "Πάριος" an grapseis "Παριος" η "ΠΑριος" ontos den tha to brei prepei na baleis kai ton tono.
Omos to katapliktiko pou kanei i 6.03 einai oti antoistixizei agglikous xaraktires me ellinikous kai ekei den einai problima oi tonoi
(oute kai an einai mikra-kefalaia)
Pou symainei oti mporeis na parameineis sta agglika kai na kaneis search se ola ta arxeia sou eite paizeis elllinika eite germanika...
Opote an grapseis "parios" tha sou brei to "Πάριος"...
Alt+shift terma...
Epeisis prepei na exei diorthothei to no1 problima" to crash sto search pou eixan polloi.
Se ayto "kratame mikro kalathi..." mexri na epibaibeothei 100% kai apo tous xristes.
Ennoeitai oti perimenoume feedback.
kleidono to topic gia na parameini se morfi anakoinosis gia tous neous xristes, i syzitisi synexizetai sto allo topic: vdj 6.xx
terra69
Limited edition user
Posted Fri 20 Nov 09 @ 3:14 pm
Paidia gia sas, exo to Virtual DJ 5 kai den ipostirizi ellinikous xaraktires.
Kseri kanis pos tha mporousa na to kano na ipostirizi i apo pou tha mporousa na katevaso ti version pou lete kai na doulevi? Dokimasa apo gamato alla den vrika tin 6.0.3 kai epipleon den douleve sosta. Thelo na stiso to programa se win 7.
Euxaristo
apopsis
Atomix Productions
Posted Fri 20 Nov 09 @ 3:30 pm
terra69 wrote :
...Kseri kanis pos tha mporousa na to kano na ipostirizi i apo pou tha mporousa na katevaso ti version pou lete kai na doulevi? Dokimasa apo gamato alla den vrika tin 6.0.3 kai epipleon den douleve sosta.
Euxaristo
Ksero ena allo ...mamato site:
