Ena software me tis vasikes leitourgies tou VirtualDJ se pragmatika elkystiki timi, gia opoion thelei na exei ena kalo software se poly xamili timi.
VirtualDJ Basic
VirtualDJ Basic, is an alternative to VirtualDJ Pro, for customers on a budget.
Designed for smaller venues, VirtualDJ Basic caters to DJ\'s who mix with a mouse and keyboard;
- it includes nearly all the features of VirtualDJ Pro, with only a few limitations.
- its currently at same version as VirtualDJ Pro, so you get the latest software engine, skin and features (with few limitations)
If you work in an environment that doesn\'t have or require hardware controllers, or the need to mix fullscreen video or karaoke, then VirtualDJ Basic will satisfy all your needs.
It supports the use of an external mixer (non midi) and can be a good choice for djs on budget, or djs having no need for external controllers, timecode etc.
Plus, if one day you get tired of mixing with a mouse and keyboard, know that you can always upgrade later to VirtualDJ Pro,
for the exact difference between the prices of VDJ Pro and VDJ Basic, so you won\'t loose any money.
Product comparison http://www.virtualdj.com/products/comparison.html
VirtualDJ Basic costs $99 (69.52 €)
BUY HERE http://www.virtualdj.com/products/basic.html
VirtualDJ Basic
geposted Fri 04 Dec 09 @ 5:32 pm
Ti den exei...
1. Video output fullscreen. Opoios thelei na kanei video mixing kai provoli se projectora, den agorazei auto , paei gia tin Pro ekdosi.
2. Den ypostirizei timecode. An thelete na xrisimopoisete cdieres kai pikap,ksexaste to.
3. Den ypostirizei midi kai HID syskeues, auto einai ena problima, alla mporeite na xrisimopoisete opoiondipote ekswteriko (oxi midi) mikti kai opoiadipote karta ixou.
Vasika auto pou skeftomai san xrisi einai i eksis...(pera apo tin klasiki PC/laptop, pontiki, pliktrologio)....
Enas ekswterikos miktis kai mia i dyo touchscreen othones pou tha paiksoun ton rollo tou midi, kai fysika ena pliktrologio gia shortcuts.
Gnwmi....An ypostirize MIDI kai HID syskeues,kai timi konta sta 100euros, tha itan No 1 se pwliseis, sigoura. !!! Einai auto akrivws pou exw ksanagrapsei (sto General Forum), oti kapoia stigmi epeidi to megethos tou software megalwnei kai varainei, tha prepe na diaxwristoun oi anagkes twn users kai na ftiaxtoun pio elafria kai euelikta software versions....
geposted Fri 04 Dec 09 @ 5:42 pm
+fwnw 100% kai epishs to fonazw xronia kai egw.Apo tote basika pou mphkan ta video.
geposted Fri 04 Dec 09 @ 6:50 pm
ondws, sto vdj h ypostirixh apo konsola einai ta panda... an kopseis auto den exeis tipota
an to prosthesoun tha ginei anarpasto
geposted Sun 06 Dec 09 @ 4:50 am
to ekana thema allh mia fora. Na dwsei ta controlers kai na kopsei entelws ta video. E3alou den ta dinei se full screen poios o logos ypar3hs tous
geposted Sun 06 Dec 09 @ 4:59 am
i have a numark total control mixer will virtual dj basic work with that ? ?
geposted Wed 10 Mar 10 @ 2:11 pm
VirtualDJ Basic Edition does not support any controllers.
geposted Wed 10 Mar 10 @ 3:56 pm
