Before I DJ, I sit down and review the music. marking cue 1 as start of song, cue 2 as vocal start, and cue 3 as end of song.
ie.
Cue1: This is where I need the music to start
Cue2: This is where I need to start the music if the guests have no patience
Cue3: This is where I should fade to the next song.
Something quiet interesting that I've noticed in Virtual DJ. When I use an AutoMix function to let it mix automatically, my cue points are not visible.
I'm looking at the software and sure, to a degree where having cue points visible would make it kinda difficult for the user to see where the automix will fade in & fade out.. big problema!!
I've also taken much time editing MixStation to create OverFlow with it's powerful Comps buttons and one button in particular provides a huge song position marker, making it quiet comfortable to see cue points and even compare them. So far, I load the upcoming track to the other deck and using the postion top/bottom, I move the fade in marker to where I need it to fade in.
Is there a better method, or perhaps a solution to this??
DJ Shahar
ie.
DJ Shahar
geposted Tue 15 Dec 09 @ 1:57 am
