I was playing with some shortcuts in the new version. But the list is quite long so it was hard to find the button attached to some shortcut. So I get the following idea:
If you add a shortcut the left pane is showing the categories like: Browser, Cues, Deck controls, etc
Add a filter combo box at the top of the "Keyboard Shortcuts" tab of the "Settings" screen. This combo has a default value of "no filter" or "All". The other options in the combo box are the values of the left pane of the add shortcut screen (Browser, Cues, Deck controls).
If you select a filter for example "Browser" you will see all the shortcuts defined for this category
Ewout
Ewout
geposted Tue 10 May 05 @ 10:32 pm
