Forum: Old versions
Topic: Virtual DJ for MAC 10.4
I'm using a mac laptop, but I'm on 10.4,
I don't have a window converter and not to keen on downloading them..
Is there a version or Virtual DJ I can download that will work on 10.4?
or.. is there a way of updating my mac to the latest version for it to work?
Whichever is easier,
I'd rather just download Virtual DJ (save any problems)
Hope to hear from you soon :)
geposted Mon 08 Feb 10 @ 12:39 pm
Hi there,
As the release of VDJ trial version for mac, it is required for it to be run on leopard or above.
As on tiger, it was no longer supported.
I'm sorry to say that in order to have VDJ mac running, you need to have to purchase the software or/and also upgrade your OSX to 10.5 or higher.
But if you bought VDJ pro, you can ask for support to sent you the last working version for tiger;)
Hope to see you with us soon;)
Regards.
I highly recommend updating to Snow Leopard - assuming your Mac is up to the specs. Not only will you able to run the latest version of VDJ (and many other modern Mac software), it's a big usability improvement compared to Tiger.
