Forum: Music discussion
Topic: What samples you use?
because I use the siren reggaeton to hook songs and to change pitch, this good that?
geposted Sun 14 Feb 10 @ 10:07 am
BlulitePRO InfinityMember since 2009
to be fair, using samples to cover up mixes is just wrong. samples are used by every person here and everyone uses different samples everytime they do a different set. samples are used to add flavour and depth to a new mix. adding a siren everytime you mix in a new track is just going to get annoying and will be noticed by your crowd.
djing is about creating new vibes and "seemless" transitions between tracks and stlyes. seemless means that there will never be the need to throw in a siren over the top of a mix unless you just effed up your mix.
geposted Sat 20 Feb 10 @ 12:25 pm
Well I usually rec samples during my set and I use it but I also use the Sample I'm Your DJ before the "strong beat" part of the track starts.
Dj DeNNy
geposted Sat 20 Feb 10 @ 12:29 pm
Yeah i use Floorfilla, but only once in a while for certain songs...never more than three times for the same gig...
geposted Sun 21 Feb 10 @ 3:07 pm
