Forum: Old versions
Topic: 5.2 skin with 6.0.5 ???
If I am using a skin that was designed at 5.2 level, what will happen if I use it with the current version?
What will I notice different?
geposted Wed 17 Feb 10 @ 10:27 pm
I am using Mixlab with ver 6.05
No problems here.
Most skins designed for VirtualDJ v5 should work OK with VirtualDJ v6.
Thank you for the feedback. Just wanted to be sure. I had noticed on skin creator there was a option to convert to v6+, so I thought there may be a lack of option.
That will attempt to convert the old VirtualDJ v5 actions to the new VDJscript used by v6.
However, v5 skins can be used without any modification necessary.
