Holding off buying the software because of this question.
geposted Fri 15 Aug 03 @ 9:00 am
DMC/DAC compatibility will be included in the next release (v1.05)
geposted Fri 15 Aug 03 @ 5:11 pm
good news ;)
geposted Fri 15 Aug 03 @ 6:04 pm
Awesome :) when does 1.05 come out?
geposted Fri 15 Aug 03 @ 6:11 pm
When can I buy version 1.5?
geposted Fri 15 Aug 03 @ 10:46 pm
If we buy the current version, is there a way to upgrade to the DMC version? Is there a discount for registered users to get the DMC version?
geposted Sat 16 Aug 03 @ 4:58 am
If you buy the current version (1.04), the 1.05 version will be free for you as soon as it's available.
geposted Sat 16 Aug 03 @ 8:06 am
hmmm that's tempting. :-)
buy now and wait for controller
wait till controller is added to the program
geposted Sat 16 Aug 03 @ 2:14 pm
What I am concerned about is that the controller version supports the following with the controller...
move through the record case
load a track using load button
start/stop deck with play / cue
bend with jog wheel
scratch with jog wheel
set cue points
temporary pitch bend +/- keys
use pitch slider to control master tempo
use pitch slider to control pitch (i.e. when master tempo is off)
LCD display to fully work (toggle time left/time elapsed)
map sliders to control volume of each deck with pitch sliders (see bpm studio as example)
Toggle effects from controller (brake, spinback, etc)
Shift mode (ability to press two keys at once to toggle function)
match bpm button and LED
Looping
I am sure I missed some functions!
I hope that all keys to be remappable so DJ can decide how the function works (maybe an ini file?)
bend with jog wheel
set cue points
Looping
geposted Sat 16 Aug 03 @ 2:31 pm
