Cool! I have a wedding this Sat.! Can't wait to use it!
geposted Mon 15 Mar 10 @ 9:35 pm
test at home befor going out on a gig
geposted Tue 16 Mar 10 @ 12:41 am
hi since I upgrade to 6.05 and now to 6.07 .I do have this bug (does any one has this ???)
ONLY THE AVI format videos v6.05 & v6.07 starts PLAYn them white . it takes about 5 secs to have the clear output . it goes from white to litle squares or pixels till having the clear video about 5 secs.
I cant belive nobody experimenting this .because I got diff laptops and its doing it in all of my laps since I upgraded. or.....are only me and my avi files ???? only my avi videos!! Looks bad, since I load the video the screen looks white till I star plyn the video takes second to have the clear image I ll apreciatte any responses
geposted Tue 16 Mar 10 @ 1:30 pm
Try another ripping software I have no problems with mine and since you are having the same problems in more then one computer it's probably the way the file was ripped.
Good Luck
Joey.....
Good Luck
Joey.....
geposted Tue 16 Mar 10 @ 3:18 pm
so you know about our ns7 problems.....are we working on it? or should i wait for vdj 7.0 with ns7/v7 soundcard as a option so mic can work video dj working and no audio drop outs
I forgot to say i updated to itch 1.5 and still 6.0.7 and doesnt work
geposted Tue 16 Mar 10 @ 8:30 pm
On my NS7 and windows xp sp3 - vdj 6.0.7 runs ver smooth :-) have tested it to for about 2 hours.
cu
pOpY
cu
pOpY
geposted Wed 17 Mar 10 @ 4:50 pm
You all remember when you install a software, you can click "custom installation" and get options to toggle on or off to be included in the installation?
Wouldn't it be nice to have options like that for updates, so you don't have to update everything at once and create new problems when all you wanted was to fix certain problems.
geposted Thu 18 Mar 10 @ 2:20 am
Thats not an option; you either replace the .exe or you don't ;)
geposted Thu 18 Mar 10 @ 10:26 am
bpmdiff now uses the deck's pitch modifications
Is it possible to let the keydiff have this feature too? (for non-keylocked decks)
geposted Sat 20 Mar 10 @ 7:32 am
Any one else notice that sometimes v. 6.0.7 will not play a video? Seems like two or three times a shift I have this happening. The audio will play but only a black screen where the video should be. Plugins still work fine but no vid. ???
DJ James
DJ James
geposted Sat 20 Mar 10 @ 4:30 pm
Quick question,to do a clean install instead of upgrade,do I need to remove exiting lisence or is there no reactivating.First time doing this with virtual dj.
geposted Sat 20 Mar 10 @ 4:59 pm
@ pop i am running W7 64bit doesnt work with 6.0.7 what is your vdj settings? maybe it has to be different now with the new up date
geposted Sun 21 Mar 10 @ 8:58 am
Here are my settings:
* Notebook - MSI GX700 - Core2Duo 2Ghz - 2GB DDR2 RAM
* XP 32bit SP3 audio optimized (if anybody want it i could upload it - but you must have an key for it!!!!)
* Numark NS7 Drivers 2.8.24
* VDJ 6.0.7 (directly update from 6.0.5 - no clean install) - but i checked the "jog - ns7_platter" assignment in my mapper
* removed battery and run just with ac power
* Deactivated some devices ... (see images) - very important is the "Microsoft ACPI battery..." - with this activated i had red bars with dpc latency checker
cu
pOpY
cu
pOpY
geposted Sun 21 Mar 10 @ 9:52 am
@popy thanks i will take look when i go home :) at work now will update around 1 am
btw
i am running
W7 64bit
320 hd 4gig ram
btw
i am running
W7 64bit
320 hd 4gig ram
geposted Sun 21 Mar 10 @ 4:41 pm
:-) i am now going to sleep ... +1h GMT :-)
Let me know.
cu
pOpY
Let me know.
cu
pOpY
geposted Sun 21 Mar 10 @ 4:48 pm
"Any one else notice that sometimes v. 6.0.7 will not play a video? Seems like two or three times a shift I have this happening. The audio will play but only a black screen where the video should be. Plugins still work fine but no vid. ???
DJ James"
Yes. I've noticed the same problem. I have to reload the track to get the video to play. Happens on vobs. mpg and avi
DJ James"
geposted Mon 22 Mar 10 @ 5:15 am
@ DJ James and Alan
Correct.I got this black screen when playing several times. I had to load the video again in the deck to get it normal. @Alan (Same thing he said.) Mpeg2 files are all that I use and they play flawlessly in 6.05 so something is amiss in this version. Keep on pressing guys. Once all these quirks are settled along with serato timecode sticker drift, then I say release the amazing v7..
geposted Mon 22 Mar 10 @ 8:38 am
I used 6.0.7 for the first full set last Friday (knew it would be a quiet night) and played mainly video, 99% VOB 1% MP4. No glitches, all videos played without a hitch...
My gig partition is Vista 32-Bit.
Cheers,
Roy
Cheers,
Roy
geposted Mon 22 Mar 10 @ 3:20 pm
DJ James
DJ James
Hi James
I also had some of the same problems you're experiencing, what I did was to re-scan BMP on the file and that resolved it for me, so give it a try..
Good Luck
Joey....
geposted Mon 22 Mar 10 @ 3:39 pm
Hi there. What do you mean by that? It is a xp kit that you have optimized or it was optimized already when you have bought it?
geposted Mon 22 Mar 10 @ 3:46 pm
