Many times I have wanted to play back-to-back tracks from a CD (especially Classic Rock albums like Pink Floyd, the Cars, Led Zeppelin, etc.) where one song runs into another, but I don't know the order to play them because I don't have the physical CD to look at. I know the program can pull info from other sources for an mp3 file (like the cover art as ripped via Windows Media player), so I am hoping this is a relatively simple addition to the fields you are already displaying.
geposted Tue 09 Mar 10 @ 7:47 pm
You could always add this to the beginning of the comment field instead. You can then show the comment field in the browser and click on its heading to sort by it (So they display in the correct order.) Make sure that you put a leading zero in front of 1 - 9 (E.g: 03) because the sorting is alphabetic.
geposted Tue 09 Mar 10 @ 8:06 pm
That's actually what I am doing now. However, I normally reserve that field for other types of info, so in effect, I am loosing a field to put in track info. Also, I have a lot of CD tracks that need this info (ripped from Dance Mix collections, etc.), so it requires a lot of manual entry on my part. Heck, Windows Media Player can display track info - why not Virtual DJ? On my system, it's already pulling the CD artwork from Windows Media Player which I used to ripped the original CDs, so why not just add the track # while you are at it?
geposted Thu 11 Mar 10 @ 12:48 pm
+1 for track number
geposted Fri 12 Mar 10 @ 9:05 am
I am also at a loss as to why a program as powerful as VDJ can't handle track numbers in the browser.
I am in the process of trying to find out what the Field 1 and Field 2 options are for. They are mentioned in the manual but only briefly. Are these user configurable?
So far, I am using Winamp to create a playlist for the albums I want to be able to play in track order and then saving that in the VDJ playlist folder.
This seems a little quicker than using the Comment field for track numbers especially when ID Tags already contain this information.
Is there any reason VDJ doesn't use track numbers?
CDJ's can play a CD in track order so why not VDJ?
geposted Tue 08 Nov 11 @ 2:24 am
You could also use the users Field #1 and Field #2 for Disc or track number, then make it display in the field tab and place it first to the left of Title...that's just an option you can use for now, hopefully the team may figure out away how to add a dedicated Disc & Track number Field in the future....
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 08 Nov 11 @ 12:03 pm
Joey, yes we could use fields #1 and #2, but I tag my files in MediaMonkey and use the ID3 tags for disk and track. Should I really have to go through that again...
ID3 is a open standard why not suport it properly...
Roy
Roy
geposted Tue 08 Nov 11 @ 7:25 pm
Comment field are there for "Comments" a track or Disc # number are Not the type of infornation that is usually found there, that's why those fields were added to help address that missing link, can also move Field 1 & 2 to the first position in the browser tab field, to the left of the Title, but we definitely need a dedicated Disc #, Track # field especially for karaoke tracks...
geposted Wed 09 Nov 11 @ 11:27 am
ditto on what the others have said.
A dedicated track number field that can be pulled in from tag info of the file or inserted by the user would make lots of sense..
Myself its not a deal breaker but their has been times I wish it had been there..
as to the karaoke tracks, I never even thought of that.. major reason right there why it needs to be added :-)
geposted Wed 09 Nov 11 @ 12:59 pm
I'm putting up a link to this thread in the "Browser related wisches and new feature" Thread where it belongs...
Link: http://www.virtualdj.com/forums/155084/Wishes_and_new_features/Browser_related_wishes_and_new_features.html
geposted Thu 10 Nov 11 @ 4:15 pm
