Look great! the 13mbp is awesome.
geposted Tue 08 Jun 10 @ 7:11 am
wide angle view of the "stage"
geposted Wed 09 Jun 10 @ 9:22 pm
Here\'s my little set up:
geposted Mon 28 Jun 10 @ 10:55 am
Another view:
![](/image/93510/35722/DSC05841.JPG)
geposted Mon 28 Jun 10 @ 11:03 am
![](/image/91099/44116/71507_166370826708405_123324521013036_566076_7175393_n.jpg)
geposted Tue 12 Oct 10 @ 4:30 pm
How u like that VCI-300 ?? I have a Hercules RMX and does the job, but I'm looking for a controller more fun to use. Do you recommend it?
I'm really not looking for anything too bulky to travel with
geposted Wed 13 Oct 10 @ 4:00 pm
I like it ok, I'd much rather use the ns7, my vci is collecting dust currently I should put it on ebay.
geposted Thu 14 Oct 10 @ 11:10 pm
![](/image/99111/44675/IMG_1194.jpg)
geposted Mon 18 Oct 10 @ 4:54 pm
stlaurents wrote :
Stlaurents: question about your case - is the laptop platform stock or an addon - it looks pretty slick!picture taken with camera phone, will upload some from my actual camera tonight. Made some changes to my rack..drilled two holes upper left corner for the power supply and USB cable for the HC4500.
I had an odessy type holder that was one of the first adapted to my old case to just slide in but that's not an option on the new (read larger case).
Looks good!
geposted Tue 19 Oct 10 @ 9:02 pm
Hey guys, here a couple of pics from a gig I did in Mauritius sept 2010.
Running my mac and m-audio controller with vdj
![](/image/20232/44931/DSC04958.JPG)
![](/image/63966/44932/DSC04869.JPG)
geposted Thu 21 Oct 10 @ 3:59 am
need help putting key code on to computer for the new pro 7 on my mac pro
geposted Sat 30 Oct 10 @ 5:24 pm
Here's mine with two decks...
![](/image/7314/47784/IMG_5941_2_1.JPG)
![](/image/24474/47785/IMG_5944_1.JPG)
And here's with four decks...
![](/image/84943/47786/IMG_5959A_1.jpg)
geposted Thu 25 Nov 10 @ 7:53 pm
what settings do you use for your mac i gave up on vdj cuase I cannot get it to run right pc nor mac with ns7
geposted Mon 10 Jan 11 @ 8:48 pm
Hi all you dj,s this is my system that i use with Virtual dj i love virtual dj way better then serato which i had prior serato is very limited to alot of things .Virtual Dj is better then serato my opinion and em a Club Video Dj and my Denon 3700,s with my Pioneer Djm-800 and Macbook pro work excellent with Vdj i love it here is i pics of some of my gear .![](/image/64967/51789/2050_1231AP.JPG)
geposted Mon 10 Jan 11 @ 9:38 pm
![](/image/86138/51790/2050_1231AT.JPG)
'Can't view your photos, Buddy. Try to reduce the size. This happened to me before too and I used photo editing software (Zoom Browser - Canon) to edit and adjust the size of my pictures. There might be some other ways, but that's how I did mine.
Goodluck!
geposted Tue 11 Jan 11 @ 1:34 pm
I don't know if your message is for me but I will try to give an answer.
I run VDJ 7.0.2 with Mac OS 10.6.4 (both on Imac and MacbookPro).
Why give up easily? There's a lot of DJs here who could help you. Just try to research more on the forum and make friends with somebody who runs the same units as yours.
Here's one of the links you could start with...
http://www.virtualdj.com/forums/140987/General_Discussion/virtual_dj_with_ns7_-_how_well_does_it_work_.html
goodluck!
ask and you shall be given
geposted Tue 11 Jan 11 @ 10:32 pm
- 15" MacBook Pro (2.53 GHZ Core 2 Duo, 4Gb 1067 MHZ DDR3)
- Mac OS X Snow Leopard 10.6.6 & Virtual DJ 7.0.2
- Denon DN-X1600 (latest firmware v2000)
- Xone:1D
Works like a charm.
- Xone:1D
Works like a charm.
![](http://img9.imageshack.us/img9/9381/xonedenon.jpg)
geposted Wed 12 Jan 11 @ 1:39 am
![](/image/7847/53520/securedownload-2.jpeg)
Imac 24"(3.06 ghz/ 500gbHD/ 4gb RAM)
2 Denon DNS-3700s
REI mixer with sampler
2 Mackie HD1521 powered mains 700w each
2 Cerwin Vega 21" powered subs 1200w each
(Room was too small for 2 subs)
Dr. Dre Beats HD Headphones(white)
geposted Sat 29 Jan 11 @ 4:18 pm
DJ Cyder wrote :![](/image/91099/44116/71507_166370826708405_123324521013036_566076_7175393_n.jpg)
I'm having issues with my mac And my NS7FX. I'm using a Macbook Pro core duo 2, 4gb of memory, and running Snow Leopard 10.6. Can you offer me some support on how to set up everything. The Issues that I'm having is that the song sound like if they are singing under water!
geposted Wed 02 Feb 11 @ 8:03 pm
hold down cue then press play, should solve it till the next update.
geposted Tue 08 Feb 11 @ 2:42 pm
