Might it be possible to get a mapper for the VTT 101.
I think i could re-work one from a file for the kontrol one or other dj tech with same jogs.
They aren't ther to be downloaded anymore.
geposted Mon 29 Mar 10 @ 1:42 pm
anyone have the old mapper for the i-mix reload that was in the downloads section?
geposted Tue 30 Mar 10 @ 9:06 am
I-mix reload Def & Mapper it's included into latest VDJ 6.0.7, if you go in the mapper page and uncheck "Show only connected devices" you will see.
geposted Tue 30 Mar 10 @ 9:40 am
yep, i know they're in there. i'm guessing the same info for the jog on reload will work the jog on the vtt(maybe a channel change here or there). that's why i wanted to look at the filles.
i should have downloaded them when i had the chance
geposted Tue 30 Mar 10 @ 10:05 am
Just like the I-Mix series, we are working with DJ-Tech to supply support for their new series of controllers. I don't have an availabilty date of when this might be complete. But we are working on it.
geposted Tue 30 Mar 10 @ 10:25 am
thank you for getting back to me
i found some info, and got it working.
geposted Tue 30 Mar 10 @ 10:49 am
let me know if anybody wants the files.
geposted Tue 30 Mar 10 @ 2:51 pm
would love a map for the imix please!!
geposted Wed 07 Apr 10 @ 6:18 am
The I-Mix series of controllers are already supported in the latest version. Please try the trial version.
geposted Wed 07 Apr 10 @ 2:09 pm
@Drimachus I would love a copy please
geposted Sun 28 Oct 12 @ 5:34 pm
Mappers are only available to registered licensed users who have purchased the full VirtualDJ Professional. External sharing is not permitted.
This controller is also natively supported in the latest version of the software, so a mapper is not necessary.
If you like VirtualDJ, please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
If you have already purchased, please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and download the latest version from your Download Center: http://www.virtualdj.com/download/updates.html
[Obsolete topic from 2010 closed.]
geposted Mon 29 Oct 12 @ 6:16 am
