Forum: Old versions
Topic: Native Instruments audio 4 and cdj 800's
Hiya could anybody help me im using virtual dj v5.2 pro i play in lots of venues now they all use pioneer cdj 800's and an allen & heath mixer i get the same problem in all the venues except one venue where it works perfect i use the Native Instruments audio 4dj with the multi-core cables and timecoded cd's the problem that i get is that when i play deck 'B' it will not return to the begining of the track ive loaded after ive played some of the track and will sometimes even stop all together after about 30 seconds of play but deck 'a' works perfect in the settings both decks are set the same
geposted Wed 31 Mar 10 @ 1:59 pm
Hey my friend I own the audio 4 dj. Can you post a youtube video of exactly what you're talking about?
1.- Check here, it seems you don't get full 100% quality and signal streng.
http://www.virtualdj.com/wiki/TimeCode%20Config.html
2.- If you are in a lot of venues, it is important to have full stability and support. To have it, Be a professional registered user. You can be one purchasing VDJ Pro on this site:
You will have your personal and nontransferable serial number and will never lost cause it would be registered in here for lifetime.
After you complete your purchase, you will be able to download all samples, effects and skins on here and also view information that is exclusive to VDJ Pro users. And also could get lifetime free updates and all available support.
