Forum: Music discussion
Topic: I need HELP with vdj Broadcasting!
hi, I am trying to broadcast to my friends and this is what appears on the link that is provided by vdj:
The webpage "174.69.123.204:8000" cannot be foundDNS error occurred. Server cannot be found. The link may be broken. Can someone PLEASE HELP me. Also, I applied to dj on virtual dj radio. Will your support fix both broadcasting modes?
geposted Thu 01 Apr 10 @ 7:29 pm
Hi,
these are two different themes ;-)
The importend thing is, when you whant to broadcast to your frined is:
Use -> Broadcast from my own computer
To get it worked, you must enable "your local" IP Adress in your router.
After that you can give the in vdj displayed complete adress to your friends.
They only have put into their winamp prog and you are on!
To play on VDJ Radio, you get all the needed informations, when it is testing time ;-)
good luck
thanks for the help.
you're welcome
Can I broadcast if I don't have wifi?
For broadcasting is always better to use a wired connection and not wi fi !
Hello
My User Name is DJJONATHAN33, and i like i wanted to knows is that i wanted to becoming it an Virtual DJ on the radio servers connections through into my Virtual DJ but Another Hands, I cannot even works it?
I'm DJ's in real life, and i have it all of the kind music on my computer into it. Can I becoming it on the listed it of the DJRadio on the Website its called: http://virtualdjradio.com/live/ , and http://virtualdjradio.com/djs/ , http://virtualdjradio.com/member/login.php too also?
Any Suggestions how i can i get it started?
