Hi guys I wonder if there is anyway that you keep all cue points and bmps when you update your vdj version?? everytime that I upgrade I lose of the data including plugins settings like TEX2D. Can somebody tell me if there is anyway that I can keep all that info..
DJ MEMO
DJ MEMO
geposted Mon 19 Apr 10 @ 1:56 am
Copy your VDJ Database and that should do it.
geposted Mon 19 Apr 10 @ 2:02 am
Just install the new version on top of the previous one.
You don't need to uninstall or delete anything.
Installing a new version will preserve all your settings, cues, etc.
The only thing that will be reset when installing a new version, is your skin (that's a security feature, in case someone install a skin without "config" button that can only get rid of by reinstalling).
geposted Mon 19 Apr 10 @ 2:41 am
Does this apply when updating from version 5.2.1? Will I still have all my virtual folders, playlists, cue points, file info etc?
geposted Mon 09 Aug 10 @ 4:50 pm
any external hard drives NEED to be connected when you do the update/run for the first time.
geposted Tue 10 Aug 10 @ 1:54 pm
Thanks again Hippydog.
Regards,
Martin
Regards,
Martin
geposted Tue 10 Aug 10 @ 3:25 pm
Correct me if I'm incorrect. V5 & V6 use diferent databases. V6 will copy & rewrite V5's database. (2 Different databases)
geposted Wed 11 Aug 10 @ 10:42 am
if you have no intention of going back to VDJ 5 you can delete that database.
geposted Thu 12 Aug 10 @ 9:20 am
is you able to have both 5.0 5.2.1 on your computer
geposted Tue 05 Oct 10 @ 12:29 pm
I have a back up of the VirtualDj directory AND the all the database files across all my harddrives.
geposted Tue 05 Oct 10 @ 12:35 pm
dizon yes it is mate at one stage i had 3 different copies of vdj.
make sure they are different names ie 5.2.1 /6.2.1 ect.i saved mine to desktop and programme folders and created shortcuts for desktop
geposted Wed 06 Oct 10 @ 1:43 pm
