Forum: Wishes and new features
Topic: Better Karaoke Features.
mad4x4PRO InfinityMember since 2009
What about
1) A Key changer that supports more than 3 Semitones
2) Key changer that can be mapped to something like the sample buttons so you can change key quicky
3) Vocal Cut Option instead of the current Music Cut Option
4) Second auto Play to work off of Side list on Second Deck with option to Que but not Play. So that you drag the karaoke tracks to the side list and they auto Cue & wait for Mix so you can get you nexxt punter up.
5) Option to Pause Play on Deck one when you Mix to Deck 2. Ie. using deck 2 for karaoke and deck 1 for background music this would let you pause the playing track while the punter is doing there turn and then return to the track onece they have finished. Rather than having to manually pause the Deck 1 after mix over.
6) Option to Quick tag a Track on the side list to Add a name temporarily again to not who is singing what
7) Karaoke Singer list that works and is integrated into the browser rather than the crap addon
8) a way to get the samples to Play and Mute / Autofade the main mix (like a talk over function on a real mixer) so you can hear them over the main mix
geposted Mon 19 Apr 10 @ 1:21 pm
apopsisdjPRO InfinitySenior staffMember since 2003
What about
You can do this already, use the integrated key changer instead of the plugin.
You can map keyboard shortcuts like this:
deck 1 key_move -1
deck 1 key_move +1
and for reset:
deck 1 key_lock off
(same for deck 2)
Then use a skin that allow you to see key changes in semitones like these :
http://www.virtualdj.com/addons/11133/Rusty.html
http://www.virtualdj.com/addons/2214/TimeCODE_POWER_variations.html
geposted Tue 20 Apr 10 @ 6:57 pm
I would like better karaoke control, i.e. to be able to log names etc
The current option is to basic, PCDJ have done it why can't VDJ?
geposted Sun 08 Aug 10 @ 12:53 pm
