I've just upgraded to the latest version and I can no longer record a jingle. It records loops but the jingle bit don't work, the button seems to be inactive. Is their a simple setting issue or am I doing something wrong.
load up track & play. press jingle button once to record, once to stop?
geposted Fri 27 May 05 @ 8:10 pm
you should get better response if you posted this in the software support forum. This forum is mainly for general discussion
geposted Sat 28 May 05 @ 5:55 am
Right: click on jingle a first time at the pos you want to start (it's getting colored) and hit another time at the end pos.
(See the manual it's well explained)
Regards,
Clax
Regards,
Clax
geposted Sat 28 May 05 @ 10:33 am
