Forum: Music discussion
Topic: Master versus headphone cue
Hello,
Probably the dumbest question of the month, but anyway: I recently downloaded VDJ Pro after using Mixmeister for years. I have been frigging around with my sound card to try to find the right setup, but my question is: when mixing, what button do I typically press to get the live sound to play, and what button do I press to hear the sound in my headphones? In Mixmeister there is a master "play" button and then a separate play button for previewing in headphones, but in VDJ Pro I only see two decks with one button under each one. If one is the live deck, then how do I preview only in my headphones on the other one?
Thanks,
Steven
geposted Fri 14 May 10 @ 12:42 pm
I just got my RMX two week ago. Although I can't figure the pre-listening concept out completely, I did figure out that there are two cue select buttons on each side of the console deck. In theory, one should be able to listen to the live music through one deck and pre-listen to the other deck through the side the is "cue selected" The problem I have run into is that I hear the cue selected side coming out of my main speaker and the my headphones as well. I've send tech support the question to try to find away to fix the issue. I'm sure its me because I am a newbie at this DJ thing. I hope that has helped you some.
Phu
Did anyone figure this out yet?
In the middle section where the master volume, cue volume, high, low , mid, under the equalizer display column (I can't think of the name right now) there is a PFL button. This has to be highlighted in order for the headphone cue to work. Once you do this you hold the cue button and you should here it in the headphones.
