The playlist cannot properly calculate the length past 13 hours and 30 minutes
(dont ask why my playlists are so long! ;-)
geposted Sat 28 May 05 @ 8:32 am
why are your playlists so long :)
geposted Sat 28 May 05 @ 10:01 am
Well since you asked ... :-)
At certain gigs, when I play all styles, I'll make playlists for each style, then one big playlists combining all the other playlists... that's what makes it go past 13 hours ;-)
geposted Sat 28 May 05 @ 5:19 pm
If your playlist contains at least one not analyzed song, then vdj cannot calculate the time.
Its not a bug... its a feature.
Check your playlist for yellow signs..
geposted Sun 29 May 05 @ 3:14 am
not true I have all my tracks scanned and I get the same bug.
geposted Sun 29 May 05 @ 3:15 am
Well i dont use so long playlists, but everytime it happens to me to have no total time calculated, it was because one or more songs not analyzed.
geposted Sun 29 May 05 @ 3:20 am
All my songs are analyzed.
It's a bug with the variable that holds the timestamp, because after 13:30 it goes negative.
geposted Sun 29 May 05 @ 9:24 am
you are right max for me is little more that 13:31:32 (48692 seconds) I just tested it
then it gets negative - cannot confirm this for other versions
I am using 3.01 (logooff fixed)
geposted Mon 30 May 05 @ 12:46 am
