The VMS4 (Velocity MIDI station) is a 4-Channel “MIDILOG™” controller that fuses both Midi (Midi software) and analog audio control (CD Players, turntables etc.) into one unit. The VMS4 is an open source controller that can be used with any Midi audio software titles (with Midi Learn feature) via it’s built-in USB port. The solid workmanship of the VMS4 makes it durable for the demanding mobile or club professional.
The VMS4 features American Audio’s signature “Velocity” touch-sensitive jog wheels, a full-function mouse pad, Midi assignable touch strips and high-quality channel and crossfaders.
This all-in-one unit has all the features found on top-of-the-line professional mixer as well, such as: Balanced XLR outputs, Gain, Treble, Mid and Bass for each Midilog™ channel, crossfader assign and curve, and 2 Microphone Inputs with Treble, Mid and Bass control.
...more at: Features
General Features:
Midi Controller with 4 USB / Analog selectable MIDILOG (Midi & Analog) channels
All audio control faders, knobs, switches, and buttons smoothed - eliminates popping, wiper noise, and zipper noise
On/off soft startup and turnoff
Gain/treble/mid/bass EQ on all MIDILOG channels
2 phono/line selectable analog channels
Two microphone channels with illuminated on/off switches and gain/treble/mid/bass EQs
On/off cueing on each MIDILOG channel
Split cueing headphones with rotary mix control
Illuminated rubber knobs for ease of use in dark environments
Solid 1.6mm thick faceplate for extra durability
Panel mounted rotary knobs
Full analog mixer operation if the computer crashes or with external power supply
Innofader replaceable crossfader compatible (sold separately)
Crossfader curve control
Crossfader assign and reverse
Q-Start crossfader controlled startup for 2 external audio players
User replaceable channel faders
Master and Booth outputs with L/R balance
Balanced Master outputs
12 position stereo master output VU meter
Bundled with VIRTUAL DJ 6 LE Software.
geposted Sat 22 May 10 @ 4:59 am
strano che un controller cosi completo per 4 deck lo diano in bundle con virtual dj...
comunque mi sembra un gran bel controller con tante cose da mappare :D
geposted Sat 22 May 10 @ 5:12 am
Questo prodotto "sulla carta" sembra molto buono, come abbiamo già detto c'è solo da verificare la qualità della scheda audio integrata...vedremo
geposted Sat 22 May 10 @ 7:19 am
è il concorrente dell' Allen & Heat DX che ho provato oggi,
questo costerà la metà.
geposted Sat 22 May 10 @ 8:32 pm
Si vabbè ma non puoi paragonare Allen & Heat con American audio dai....
Comunque sull'ultimo Virtual DJ 6.1 è gia mappato.
geposted Sat 22 May 10 @ 11:42 pm
ho appena finito di parlare con l'agente AmericanAudio...consegne previste per meta'/fine Giugno...in questi giorni mi fa sapere anche il prezzo!!
geposted Tue 25 May 10 @ 4:11 am
Bene!
Grazie.
Grazie.
geposted Tue 25 May 10 @ 6:00 am
La versione LE di Virtual DJ 6 avrà anche una skin dedicata!
geposted Sun 06 Jun 10 @ 7:04 am
Mancano degli sliders...
geposted Sun 06 Jun 10 @ 7:56 am
Virtual DJ ha solo 2 deck e non sarebbe servito a niente mettere sulla skin degli slyder solo per bel vedere ;)
Qualcosa sembra che manchi però !
Potrà essere un'impressione ottica.... ma non vedo la monopolina dello slyder del volume deck 2 :))
Buon mix da Max....'(-_-)'
geposted Sun 06 Jun 10 @ 8:23 am
Nemmeno e' uscita e già c'ha un BUG! XD ahah ahaah
geposted Sun 06 Jun 10 @ 9:58 am
...ma io scherzavo...
geposted Sun 06 Jun 10 @ 11:34 am
Il rappresentante American Audio mi ha confermato l'arrivo per fine mese..
geposted Tue 06 Jul 10 @ 3:14 am
Ottimo!
Andrea
Andrea
geposted Tue 06 Jul 10 @ 4:25 am
attenzione videomixatori
con queata consolle si apre una nuova frontiera creativa
mappando il fade to black sullo slider 1 e volume sul 2
mappando il fade to black sullo slider 3 e volume sul 4
durante un mixaggio si puo' mantenere il volume costante e giocare con la dissolvenza
rimane il crossfader da linkare o slinkare per altri giochetti.
quindi non 4 canali , ma 2 con 2 controlli aggiuntivi.
geposted Tue 06 Jul 10 @ 4:11 pm
io sarei curioso di conoscere...
questi...
"giochetti"...
non ne trovo l'utilità....
(a parte quella di sostituire la xponent!!! ) :P
questi...
"giochetti"...
geposted Wed 07 Jul 10 @ 8:29 am
questi giochetti sono utili se si usano piu' di 2 fonti video alla volta.
Usare il fade to balck su slider indipendente
non e' tanto diverso da usare il cross fader video con una transizione FADE
e un video in pausa su scena nera sull'altro deck.
Volendo si puo' escogitare qualcosa per dissolvere foto slideshow o clipbank
ma troverebbero piu' utilita' se fossero su deck aggiuntivi,
che VDJ puo' fare solo in MultiIstanza (ben critica in videoMix).
Augh !
Augh !
geposted Wed 07 Jul 10 @ 9:52 am
certo che qui la fantasia fa un po' difetto
in Discoteca ci sono delle situazioni che il Light Jockey fa il "Buio"
i video purtroppo sparano troppa luce,
vedi la mia situazione in capannina
che ovviavo scaricando il deck opposto e spostando il crossfader slinkato dall'audio (ma avevo un deck occupato)
ad esempio su Guru josh - Infinity si crea l'atmosfera anche andando a Buio e riaccendendo il Video
immagina:
slide 1 - vai a buio
slide 2 - alzi il volume
slide 3 - ininfluente - ma sul deck 2 hai una JPG dello sponsor
slide 4 - illumini o scurisci la jpg
cossfader slinkato - giochi tra Clip e sponsor
e data la vicinanza dei comandi , bastano 2 mani
provero' con il djm-5000 :-)
anche se il fade to black in quesata modalita slinkata va impostato inverted, slide abbassato: tutta luce , slide a picco: buio
immagina:
geposted Thu 08 Jul 10 @ 10:48 am
Una curiosità...visto che nei primi di Agosto è prevista la consegna..ho notato che in Vdj 6.08 non è presente nell'elenco dei Mappers...nella 6.1 è presente questo controller?
geposted Thu 22 Jul 10 @ 6:10 am
si. mappato nella 6.1 oltre al DP2 ed ai Radius
geposted Thu 22 Jul 10 @ 6:38 am
