![](/image/8019/33147/vms4_controller_faceplace_1100_v2.gif)
The VMS4 (Velocity MIDI station) is a 4-Channel “MIDILOG™” controller that fuses both Midi (Midi software) and analog audio control (CD Players, turntables etc.) into one unit. The VMS4 is an open source controller that can be used with any Midi audio software titles (with Midi Learn feature) via it’s built-in USB port. The solid workmanship of the VMS4 makes it durable for the demanding mobile or club professional.
The VMS4 features American Audio’s signature “Velocity” touch-sensitive jog wheels, a full-function mouse pad, Midi assignable touch strips and high-quality channel and crossfaders.
This all-in-one unit has all the features found on top-of-the-line professional mixer as well, such as: Balanced XLR outputs, Gain, Treble, Mid and Bass for each Midilog™ channel, crossfader assign and curve, and 2 Microphone Inputs with Treble, Mid and Bass control.
...more at: Features
General Features:
Midi Controller with 4 USB / Analog selectable MIDILOG (Midi & Analog) channels
All audio control faders, knobs, switches, and buttons smoothed - eliminates popping, wiper noise, and zipper noise
On/off soft startup and turnoff
Gain/treble/mid/bass EQ on all MIDILOG channels
2 phono/line selectable analog channels
Two microphone channels with illuminated on/off switches and gain/treble/mid/bass EQs
On/off cueing on each MIDILOG channel
Split cueing headphones with rotary mix control
Illuminated rubber knobs for ease of use in dark environments
Solid 1.6mm thick faceplate for extra durability
Panel mounted rotary knobs
Full analog mixer operation if the computer crashes or with external power supply
Innofader replaceable crossfader compatible (sold separately)
Crossfader curve control
Crossfader assign and reverse
Q-Start crossfader controlled startup for 2 external audio players
User replaceable channel faders
Master and Booth outputs with L/R balance
Balanced Master outputs
12 position stereo master output VU meter
Bundled with VIRTUAL DJ 6 LE Software.
![](/image/92616/33148/virtualdj_bundled.jpg)
geposted Sat 22 May 10 @ 4:59 am
