I know alot of us have to disable our wireless cards and other troublesome devices that cause issues
I created a stop/start script for all devices that I do not want enabled while I gig by using devcon
you can read up on it from microsoft here:
http://support.microsoft.com/kb/311272
Heres the script I have for my machine
just simple batch file (.bat)
echo Killing The Wired Network Card
c:\winddk\7600.16385.1\Tools\devcon\amd64\devcon disable PCI\VEN_1969*
echo Killing The Wireless Network Card
c:\winddk\7600.16385.1\Tools\devcon\amd64\devcon disable PCI\VEN_168*
echo Killing The WebCam
c:\winddk\7600.16385.1\Tools\devcon\amd64\devcon disable USB\VID_04F2*
echo Killing On Board Sound Card
c:\winddk\7600.16385.1\Tools\devcon\amd64\devcon disable HDAUDIO\FUNC_01*
pause
write the same script but replace disable with enable to get your drivers going again.
Thanks,
DJ SMG!!
pause
Thanks,
DJ SMG!!
geposted Sat 22 May 10 @ 7:41 pm
Also you can use the SC Command to disable and enable serives as needed.
This can save you some time... when preparing for a gig.. Double click and your set..
Cheers
Cheers
geposted Sat 22 May 10 @ 7:48 pm
or you can get this nifty app...
http://www.iobit.com/gamebooster.html
geposted Sat 22 May 10 @ 8:45 pm
great link guys thanks
geposted Sun 23 May 10 @ 5:48 am
Im not a fan of game booster, at least not on my win.7 machine. Every time I have used it my system became unstable and VDJ would actually lose performance.
geposted Sun 23 May 10 @ 7:48 pm
