hey...i use virtual dj at work (radio sation) so i try to incooperate alot of jingles in the mix..
the current sample engine/manager in vdj is cool but sometimes it takes alot of time to load up different samples as we are currently limited to only 12 at a time.
so i'm thinking, it would be great if we could get 3 sample banks in vdj ..each bank would have 12 slots (like the one we have now) so it would be 3x12... it would be pretty cool to have 36 samples loaded and ready to go
only one (1) bank would be active at a time (who would want to press all 36 at the same time?) so the same function keys F1 - F12 could be used on each bank
then you could assign a key like tab or backspace to switch through the banks
VDJ TEAM IT WOULD BE AWSOME IF YOU COULD IMPLEMENT THIS IN THE NEXT RELEASE OF VDJ
geposted Wed 26 May 10 @ 8:08 pm
You could always use VDJScript to create sample banks.
geposted Thu 27 May 10 @ 5:21 am
There is radio playlist software available to do exactly what you want but it's quite expensive and not that well publicised.
geposted Thu 27 May 10 @ 10:05 am
This sounds interesting! Where can I find out how?
geposted Sat 12 Jun 10 @ 6:43 am
You just map a skin button, keyboard key or controller key to perform a bunch of sample select x & sample load "x" commands chained together.
geposted Sat 12 Jun 10 @ 7:10 am
Thanks for the tip, I'm gonna have a look at this today!
geposted Sat 12 Jun 10 @ 7:38 am
Accidentally found some freeware, exactly what most of us have been looking for, check my post out here....
http://www.virtualdj.com/forums/130098/General_Discussion/Jingles_Drops_Samples_-_Multi_Banks_(Solution_for_most).html
geposted Tue 15 Jun 10 @ 7:12 am
please I have external mappers but when I put them in the mappers it doesn't work
please what will b the cause ? it was working but suddenly it stopped
geposted Sun 23 Dec 18 @ 1:45 pm
This thread is about sample banks. Why are you asking about mappers here?
You have external mappers - for what? To use VDJ with controllers you need a license.
geposted Sun 23 Dec 18 @ 2:04 pm
