1) song length without analaysing, if windows media player can do so can you.
2) drag a song and scroll the list, today you cannot drag a song to a specific place in the list if it is not shown , you have to first scroll to the position and then drag, add drag and scroll.
3) fader style and length in the main screen.
4) select more than 1 song with the mouse, sometimes you work only with the mouse and if you want to select several or all ( a select all button is also needed) soings you must use the keyboard. maybe you can select with the mouse like in a regular windows explorer.
5) dbl click on a playlist in a windows folder should opoen virtual SJ with the list in the queue of songs and start playing.
that's it for now, i think these are very useful features....
10x
10x
geposted Mon 30 May 05 @ 1:00 pm
select all = ctl+a
fader style check out djcel's crossfader plugin, and the simple mix plugin
geposted Mon 30 May 05 @ 1:28 pm
ctrl+a not good i wanted to use only the mouse (one hand) so maybe a select all button or a selction zone to select files with mouse.
geposted Mon 30 May 05 @ 3:31 pm
