Hi, as I understand it, the VDJ software available now is considered the semi-pro version. VDJ are soon to offer a pro version when the XP10 is released. Is this a play on words or is the pro-version VDJ software really different to the "semi pro" version, or is it just that if you have the XP10 controller hardware it is considered the pro version/setup?
Reason I ask, is I am contemplating buying the software and want to know if I should hold off until XP10 release before buying.
Thanks
Thanks
geposted Mon 18 Aug 03 @ 2:14 pm
The "semi-pro" version is the exact same software as in the "pro" version. The only difference is the hardware controller.
geposted Mon 18 Aug 03 @ 3:43 pm
OK thanks for clarifying that for me appreciated. One other point, can I assume that the XP10 is 499 euros on its own or is this the bundle price for the software and hardware i.e software is 99e and the hardware 400e?
geposted Tue 19 Aug 03 @ 12:04 am
