I was playing around with the options in the latest vdj as I had a fatal error occur while searching for some tracks and clicked on dont search in the options menu. Now all my cue points have gone after the ammount of time it took me to set them. Is there any way I can retrieve them please. Thanx in advance
Heres a copy of the crash guard report if that helps
Crash ID=7584acae (date=1006082055, version=6.0.8 Basic, build=608, thread=CoverFlow, dump=880646ff, ex
geposted Fri 11 Jun 10 @ 9:20 am
if you have a copy of the xml file yes it is. look in my blog and there is a tutorial that may help you.
geposted Fri 11 Jun 10 @ 10:35 am
Just had a look and there is no info in ur blog
geposted Fri 11 Jun 10 @ 11:35 am
Unfortunately, if you haven't backed up your xml file, you're out of luck. I've formed a habit of backing up whenever I make a change, in addition to regular backups. I copy the entire VirtualDJ folder into a backup folder so that I can retrieve vital info. when I get myself in hot water. It's a good practice, and might keep you up and running when you would otherwise have problems. I know that I haven't really addressed the problem at hand, but I hope that it will help you in the future. BTW, if you use an external drive, put the xml file from that drive into your backup folder also.
geposted Fri 11 Jun 10 @ 2:21 pm
Ok thanks for your advise. I will do that from now on. I have a 500gb laptop hard drive and had about 100gb of music cued up. Just one question which is where do I or how do I get to these xml files you speak of please ? I do have an external hard drive so can put them on here with no probs .
geposted Fri 11 Jun 10 @ 5:10 pm
Apologies to moderator for dbl thread .
Earlier today I lost all my cue points after resetting vdj (the latest version. Now I have just started cueing up tracks again, turned of my laptop for a few hrs only to put it back on and find that they have all disappeared again. What have I disturbed please. Also when I change the skin and close vdj down. When I then open it, It all goes back to default .
geposted Fri 11 Jun 10 @ 8:06 pm
oops sorry, that one went on walk about...
geposted Fri 11 Jun 10 @ 8:08 pm
