Forum: Old versions
Topic: Vestax Typhoon and VDJ - Page: 1
Hi guys, had a search thru here but can only find spin related stuff.
Basically im looking to see if theres a mapper for this unit, ive tried it already with the "spin" map and it doesnt work for me...
Any ideas?
Thanks
geposted Sat 26 Jun 10 @ 2:22 pm
Hello del200,
I have tested on a Mac and on Windows:
- on my Mac, in Mac OS 10.5.5, VirtualDJ 6.1 Pro + Spin (map built in VirtualDJ), everything runs OK
- on Windows XP, VirtualDJ 6.1 Pro + Spin (map built in VirtualDJ), the output channel for master and preview is just deck A + deck B, regardless of the position of the crossfader.
Hey thanks for the reply, but i cant make sense of the midi thing, do i have to make my own map? or is there one available for the typhoon, my audion set up is fine.
When i plug in the typhoon, random lights light up on the unit and i get no interface control at all
thanks again
What Cioce wanted you do was to download and run the following application:
https://virtualdj.com/download/miditrace.exe
In the two boxes on the left hand side, select the Typhoon (which will probably be seen as USB Audio device)
Next , click the SEND button at the top.
This will display some numbers. Copy and post the first line (which should start with F0 7E 7F 06 ...), so Cioce (or someone else) can modify the SPIN mapping to recognize the Typhoon.
Hello Cioce,
You are right, it works in Windows XP with ASIO4ALL (I had disabled the crossfader in option menu, that is why I got only Deck A+Deck B).
Spin + VirtualDJ 6.1 Pro work
- this ASIO4ALL setting
- this Sound Setup
- this Mapper setting (VirtualDJ 6.1 Pro defaut map for Spin).
Hi again guys...
So i highlight both typhoon options click send and these are the results...
F0 7E 00 06 02 00 40 02 20 01 00 00 00 29 00 11 F7
B0 0C 12 00
B0 14 00 00
B0 15 57 00
B0 16 40 00
B0 17 40 00
B0 0E 37 00
B2 51 00 00
B2 52 07 00
B1 0C 00 00
B1 14 00 00
B1 17 00 00
B1 16 27 00
B1 15 3A 00
B1 0E 57 00
B2 08 5F 00
Hope this is of help!
Thanks
The Vestax Typhoon support is being worked on by the manufacture. When they find that it is ready ... then we will make it available for download.
Thanks for info Phatso, I have updated my blog.
Hi again folks thanks for replies,
Any idea on a timescale for this control being operational?
Thanks again.
Yup and to confirm the vestax asio works good thru it, even without control haha
Hello again guys any update on the compatibilty of these products yet? I'm hangging out to use them publicly together
Thanks del
As I stated above:
guyz can u help me ,how to used my vestax typhoon on vdj,tnx guyz
Hi
I know its being worked on and i know its been said but any idea when if at all this will be ready
Hello
I get the just not down with the mapping itself, can someone write one for the Typhoon?
it goes with VDJ 6 ... it only lights up the cue button nothing else.
With the tractor makes the mix for me no fun ... I find virtual dj every time better!
thank you
Im glad to hear that I'm not the only who thinks the Virtual DJ is a better choice thank Traktor.....
I just bought my Vestax Typhoon 3 days ago, and already Im looking for a better solution. Lucky for me I had a friend show me the difference that the Virtual DJ software made on his Ion Discover DJ, and I'm sold.
So I sit here asking the same question that seems to be on a lot of peoples minds.
1. Does Virtual DJ support the Vestax Typhoon unit?
2. Are my only options to buy the Pro version?
3. Does the demo version also support the Vestax Typhoon, so that I can give it a whirl before spending some cash?
Thanks in advance to anyone that can help,
DJ NoNameYet
1. The Vestax Typhoon is not supported yet, but should be soon.
2. VirtualDJ Pro is required to use MIDI controllers.
3. A future version of the demo will support the Typhoon, once support has been added.
Please make this quick ! I can´t wait to use my typhoon with VDJ. :-)
Good day to all. Can somebody in here help me. I have a Vestax Typhoon and I manage to map my machine in VDJ. My problem is when I start VDJ and begin to use the machine some buttons lights up automatically. Can somebody help me with this?
37%
