Topic: VCI 300 MK2
When i had my VCI 300.. There were certain things that were not ok. The sound good but not that great and a few other things missing.. Vestax has improved the VCI 300 with a MK2 model.
TOP OF THE LEAGUE
In 2008, the VCI-300+ITCH was the beginning for Vestax and Serato to create a new DJ console of the next generation.
The goal was clear. To design a light weight and compact digital DJ instrument with the touch of analog control.
Preserving the concept of the VCI-300+ITCH, the VCI-300MKII comes with usability improvements based on feedback from VCI-300 customers.
Vestax has considered every comment that has been received, and have put them all in act. Simply to give DJs what they want.
•HIGH RESOLUTION CONTROL
The VCI-300MKII can control more than 90 parameters and functions of the included Serato software with high resolution MIDI signals sent via USB. The pulse resolution of the JOG wheel and pitch control fader is 4 times higher than the VCI-100 and provides precise control of each function. The pitch control fader also shares the same high quality fader parts of the input fader for advanced operability.
•SUPERB AUDIO CHARACTERISTIC
The built-in audio interface carries a Audio Codec IC with superb audio characteristic, generated by a delta-sigma modulation 24 bit stereo D/A-A/D converter. Audio connection includes 1 stereo input, 1 MIC input and 2 stereo output (Master L/R, Monitor L/R).
•LEVEL INDICATION
A 12 level LED L/R indicator is set in the center of the top panel to monitor sound levels.
•FILE CONTROL
Audio files in the software library can be easily selected and controlled with the CRATES / FILES / BROWSE key and the cursor switch inherited from the VCM-100.
•EMERGENCY THRU SWITCH
The Emergency Thru Switch located on the rear panel is a countermeasure where you can use the VCI-300MKII with the provided ITCH software or without the computer connected if you simply want to play music from your external CD or MP3 player. The ITCH software reads music from your iTunes library or the Serato library you use for Scratch LIVE, making it the perfect device for recreational or professional DJ\'s.
•ADJUSTABLE JOG WHEEL TORQUE
The torque of each JOG wheel can be adjusted to prevent them from moving from low frequency feedback and altering the pitch when using the VCI-300 in such places like clubs.
•FADER CURVE CONTROL
The fader curve of each fader can be adjusted to the preferred characteristics for long mixes, scratching and any other style.
geposted Thu 08 Jul 10 @ 1:50 am
Thanks for the info,
But all this is, is a last minute attempt to try and take a few sales away from American Audio however it doesn't even come close.
They ought to rebuild and come out with a Analogue/Digital bad boy too.
Think i'll just carry on with my RMX as i'm not interested in the VS4 as i don't like the quality of the AA stuff.
Is this a promo advert? lol
VCI-300 MKII Improvements include:
Volume Boost
Higher output gain level and headphone volume level when supplying power with the optional power adaptor (not included).
Optional Vestax Digital Fader (not included)
Crossfader can be upgraded to Vestax's new magnetic sensor system digital fader CF-X2.
Direct Audio Thru
Audio fed to the MIC/AUX input can now be directly sent to the Master outputs with the THRU switch turned ON, minimizing latency of when fed through ITCH.
Improved Touch Sensor Level control
New, easily adjustable Touch Sensor Level control knobs.
THRU Switch
MIC/AUX input can be output directly without being fed to ITCH software.
Mini headphone jack
Added 1/8 inch headphone connection along with standard 1/4 inch connection
i have the vci 300 is verygood, i ordered the VCI 300 mkII
i love this controller ;o)
Is this a good controller for scratching with VDJ if used with other sound card?
scratch works well, but better with serato itch (sorry virtual dj)
the vci 300 works well with external sound card and virtual dj
you can use the built-soundcard, works verygood with asio4all and virtual dj
