What I would like to see is a way to have the TimeCode default set to 'OFF' when I have VDJ configured for TimeCode Low Latency Use.
I use the TCVs with the DAC-2, and most of the time I don't start out with the TCVs and since I do mobile gigs I usually don't lug TTs with me. But when I start VDJ, the first thing I have to do is click my TC button on the skin or use the shortcut to de-activate TC use before the DAC-2 buttons will work.
Can't this be added as a simple check box setting in the Config of the TC. Option maybe reading "TC Active at Startup" - checked means Yes, unchecked means No.
Thanks if you can add this to the next release.
cstoll
cstoll
geposted Tue 07 Jun 05 @ 5:10 am
