Just wondering if this is possible. Or if anyone has a better way of creating karaoke songbooks without have to type out each song individually.
geposted Tue 03 Aug 10 @ 11:08 am
just google karaoke songlists will be your best bet.
geposted Tue 03 Aug 10 @ 2:12 pm
every swinging dick has a karaoke songlist/book creator, recommending "google" is fail
I'd be interested in some of programs some other KJ's use (favorites) as well
geposted Fri 06 Aug 10 @ 3:05 am
Hey you can use someones advice or not and as I'm the only one so far to offer it, just don't be so ungrateful when you didn't even ask the question, it's not done around here.
@davedallas there are some good options on google, you have to try out a few until you find one that suits your own needs.
geposted Fri 06 Aug 10 @ 4:45 am
Thank You Tayla. Just got done with a busy weekend so I'll probably do some research tomorrow when have more time.
geposted Sun 08 Aug 10 @ 9:19 pm
Did some Googleing and found this program. After trying the demo I bought it instantly. Does exactly what I want. Scans all my karaoke files and puts them into a professional looking book. I will have to rename some of my titles but way easier than any other way:)
http://www.latshawsystems.com/ProductDetails_SongListGenerator.aspx
geposted Wed 11 Aug 10 @ 1:57 pm
glad you found one that you like.
geposted Wed 11 Aug 10 @ 2:30 pm
Me too, thanx
geposted Wed 11 Aug 10 @ 11:34 pm
Hey I am new to DJ'ing profesionaly.....bought some nice equipment..been toying around with it for years for free with household electronics.
I have Virtual DJ Pro....I want to get into Karaoke using this program. I have alot of Karaoke CD+G cd's....any suggestions or advice on how to get started?
geposted Mon 06 Sep 10 @ 11:19 am
Sure, just spent about 5 weeks with three computers ripping all of my CD+G's into a zip format using Power Karaoke's ripping program:
http://www.powerkaraoke.com/src/prod_powercdgburner.php
Works like a charm. You can set your output folder, your bitrate and format. Plus it will automatically name most CD+G's. You should remove track number from the output titler just because it will bother you later when trying to make books because in front of every artist is a track number so you'll have say: a brooks, garth section and a few sections that are like: 12 brooks, garth and 5 brooks, garth
using this and the book making program i mentioned earlier in this thread there are only a few titles you'll have to rename manually. I'm too anal to have a garth brooks section and a brooks, garth section.
Hope this helps:)
Hope this helps:)
geposted Tue 07 Sep 10 @ 11:07 am
