Forum: Old versions
Topic: American Audio VMS4 Discussions - Page: 26
I knew it was so .. FadeToBlack my problem was, now works with the corossfader for the video part and the sliders for the audio, you can not set the AUTO LINK. I can also do so, perhaps that is better, but I wish I could choose ....
Thanks
djdad wrote :
In case you run video...
then assign ..
L_FX_ASSIGN_1 .... deck 3 leftcross 'only' & deck 3 leftvideo
L_FX_ASSIGN_2 ... deck 1 leftcross 'only' & deck 1 leftvideo
L_FX_ASSIGN_3 .... deck 2 leftcross 'only' & deck 2 leftvideo
L_FX_ASSIGN_4 ... deck 4 leftcross 'only' & deck 4 leftvideo
R_FX_ASSIGN_1 .... deck 3 rightcross 'only' & deck 3 rightvideo
R_FX_ASSIGN_2 ... deck 1 rightcross 'only' & deck 1 rightvideo
R_FX_ASSIGN_3 .... deck 2 rightcross 'only' & deck 2 rightvideo
R_FX_ASSIGN_4 ... deck 4 rightcross 'only' & deck 4 rightvideo
Then assign the VMS4 crossfader as ..
fake_crossfader & video_crossfader
OK I found a bug using the VMS4 with VDJ 7.0.1. May not just be with the VMS4.
I had deck 2 playing and hitting the cue button on deck one as a stutter. It was making deck 2 pause for a second the more I hit it.
Can anyone else recreate what I'm experiencing?
No one else? I guess it's just me.
yes... try (if neccessary) upgrade firmware
I did.
I try to find the best way to record with VMS4.
What i've done..
Advanced Config.
Deck 1 ..ASIO.. 3&4
Deck 2 ..ASIO .. 5&6
Deck 3 .. ASIO .. 7&8
RecordLoopback ..ASIO .. Inputs 1&2
I connected with RCA the Booth output and the Ch1&2 line inputs in VMS4. 8out mode. This way i can record properly using mics too. Since VMS4 is an analoque external mixer, i can not find another way.
Am i doing the right thing, or is there another way too?
help !!
how can get led "on" or "off" on hot_cue4 button ?
i made this change :
jog :
wheel_mode "browser" ? device_side left ? browser_window "folders,folders" & jogwheel : browser_window "songs,songs" & jogwheel : touchwheel
hot_cue4 :
wheel_mode "browser" ? deck left wheel_mode "jog" & deck right wheel_mode "jog" : deck left wheel_mode "browser" & deck right wheel_mode "browser"
with hotcue4 button i change between jog and search with the jogwheel (and works great, but i dont know when i have jog or browser selected)
i would like to have a led (hotcue4) "on" when browser is selected, and led (hotcue4) "off" when jog is selected
is posible ?
thanks
If you want it to light red..
map the LED_HOT_CUE4 as ..
wheel_mode "browser" ? on : off
and the LED_HOT_CUE8 as
off
If you want it to light purple ...
off
thanks for the answer djdad
nop, it doesnt work, wich would be the prblem ?
into config - mappers i put
into key learn box
led_hot_cue4
and in action : wheel_mode "browser" ? on : off
and again with led_hot_cue8
off
but i cant get the light
what i did wrong ?
thanks
nop, it doesnt work, wich would be the problem ?
into key learn box
led_hot_cue4
off
what i did wrong ?
thanks
What i've done..
Advanced Config.
Deck 1 ..ASIO.. 3&4
This is what I do and is the correct way. The only change I have to your config is that I have the sampler mapped to outputs 7&8. This is because I am broadcasting rather than recording, but it's the same principle.
Works really well.
Roy
Hello. How to set up 4 deck 2turntable timecode vinyl + VMS4 (line 1 = 1left turntable line 2 = deck 1 vms4 line 3 = deck 2 vms4 line 4 = 1right turntable) . i had skin 4 deck . everything for virtual dj 6.1.2 on mac osx . help me please. thank a lot.
hi guys
first my English is not very good
like you i up grated from the xponent to vms4
the first vms4 had big problems and i returned it the next day
the new one is configured and works BUT 3 issue
1 the sound that comes out is week and if i raise the volume it gets distorted it does not play loud enough for the gigs
2 head phones are not working properly
3 if i cant fix the first issue can i add numark djio as a sound card the volume increases by 200% but i have no control on the knobs
so can some one help me out before i return the unit to the store
thanks
dj chico
Issue 1 has been known about since day 1 and AA do not have a solution. If it is no good for you then return the unit as there is no fix for this.
Isdue 2 can you explain more, is it a problem with volume or cueing channels?
Keith
HELP ME PLEASE................................................. THANK YOU THANK A LOT.
@fer14. I tried in my VMS4 and this way it works for me
JOG
HOT_CUE4 :
LED_HOT_CUE4
Try it.
dj dad thanks a lot for your time
i try but it doesnt work, i dont know why, i try with other actions (play,loop,wheel_mode) and it doesnt work too. only led works wit hotcue4 and 8 action.
i ask to support, waiting answer
i have windows 7 maybe is the problem, i couldnt also upgrade firmware (get a message : cannot open device)
thanks
spider1111 wrote :
I'm still in 2 minds about getting an external soundcard 2 better the sound quality of the sound from my vms4 was lookin at the Maya 44, does this improve the sound that much?? N was thinking about getting an FireWire 1 can anyone reconned me a good one?
Cheers
i am using the Presonus firebox with the vci-100 right now and was thinking of giving the vms4 a try but wanted to continue to use my firebox for sound, does the vms4 still work well using a different sound card?
You can use the VMS4 purely as a midi controller and route the sound to a better quality card if you wish.
Sort of defeats the purpose of having an all in one however the VMS4 output is low and distorts if pushed.
Keith
75%
