I have the limited edition and when i click on the "more" button it says that i can try the pro edition for 20 days. Now did i download it first then i hit the 20 day trial button or what...
geposted Sun 08 Aug 10 @ 11:23 am
Virtual DJ is already installed.
Once you click the Trial button, the LE verison you currently have will give you access to the option of the Pro version (v5) for 20 days. Once this period is over, you will be returned to the LE configuration you currently use.
geposted Mon 09 Aug 10 @ 6:27 am
i have a school computer and i dont want to download it on here so how do i just get the free trail for now?
geposted Fri 01 Apr 11 @ 5:02 pm
Sorry, there is no free trial any more - Instead, we now offer VirtualDJ Home FREE http://www.virtualdj.com/download/free.html which is free for non-commercial use. It also allows VirtualDJ Pro features to be tried for 10 minutes at a time.
See http://www.virtualdj.com/products/comparison.html for a comparison between the different versions.
geposted Fri 01 Apr 11 @ 5:38 pm
how do you get the trial of virtual dj pro. i have the virtual dj home installed. where is the trial button?
geposted Sun 17 Apr 11 @ 9:06 pm
@harrisonkauth - please refer to the post directly previous to yours made by Support Staff. There is no longer a free trial of Pro available.
geposted Mon 18 Apr 11 @ 12:20 am
In Home FREE the trial of Pro features will automatically activate if you have a MIDI controller connected. Or you can go to CONFIG -> Sound Setup and click MORE.
The Pro features will be active for 10 minutes after which it will expire and revert back to limited features of Home FREE: http://www.virtualdj.com/products/comparison.html
NOTE: For basic keyboard/mouse use, you do not need to activate this.
geposted Mon 18 Apr 11 @ 7:02 am
were is the trial button can't find it and i really wanna get starting
geposted Fri 14 Jun 13 @ 1:29 am
oh nevermind no more free trial well that was a bummer to bad :) :( :p
geposted Fri 14 Jun 13 @ 1:34 am
You can use VirtualDJ Home FREE to try out the software.: http://www.virtualdj.com/download/free.html
Pro features such as MIDI controllers, advanced sound card config, etc. are limited to 10 minutes at a time, but you can restart the software as many times as you need to gain a further 10 minutes.
If you are just using mouse/keyboard, then Home FREE can be used as long as you like, providing it's for non-commercial home use. To use VIrtualDJ at gigs where you are being paid, you will need to purchase the software: http://www.virtualdj.com/products/comparison.html
geposted Fri 14 Jun 13 @ 4:26 am
Omg.... too many trolls?
or too many stupid people?
pff...
pff...
geposted Fri 14 Jun 13 @ 2:24 pm
i wanna try it before i buy it
geposted Fri 16 Dec 16 @ 5:10 am
Download v8 you'll get as many 10 minute trials as you like.
geposted Fri 16 Dec 16 @ 5:45 am
YES! Created an account for nothing. 10 minutes, what is the cd time? Was under the impression I would get to navigate through this program. not dropping 300 usd (monthly is a waste) to see what I can remap on my controller that serato doesnt offer. Serato is now stable & nothing lost here but time. (a dj thats taking over a bar came w vdj, been years since ive fooled w the program) will be a few more if not longer. Thank you for all of the comments that led to my conclusion. industry standard in the US if you want my 2 cents.
geposted Wed 06 Jun 18 @ 11:08 pm
installer link
geposted Tue 03 Dec 19 @ 1:14 pm
