sounds good.....and she remembered your name!
geposted Mon 24 Sep 12 @ 7:41 am
i help me to put my name in the virtual dj skin
geposted Thu 04 Oct 12 @ 11:02 am
DJ DRROP NAM SOFTWERE NOT A AVALAVLE FOR VARTUAL PLZ HELP
geposted Tue 05 Feb 13 @ 4:25 am
i like reading these
geposted Wed 06 Feb 13 @ 2:54 pm
Hell I just use my sound recorder on my computer (after narrowing down mic input to the 3.5mm) and finding a quiet room in my castle (with the wife and 4 dogs and 1 cat ..... geez I need a man cave BADLY ) record it on sound recorder , afterwards run it thru wave pad a few effects and tweaks and presto change o a dj drop takes about 30 secs guys really .... I aint that hard
geposted Sat 09 Feb 13 @ 5:06 pm
yeap! Same here. I used my kids Rockband USB Mic (1/8 mic input on laptop is broken). Asked wife and kids to leave the room, press record in Audacity, made a couple tweaks and BOOM there you go! After that I just sampled it in VDJ! Now I can scratch with it if I want or just press the sampler key to activate it..
geposted Sun 10 Feb 13 @ 12:12 am
hi sir my name is indresh and indreshdj clip
geposted Mon 25 Mar 13 @ 11:38 am
I don't mean to come off as a jerk but some of you sound like this guy.
Get a grip for crying out loud and pay for the sample!
http://youtu.be/fztNCJy-GXI
geposted Mon 25 Mar 13 @ 12:01 pm
I had a full package of 10 made by Chuck Fresh in the USA about 10 years ago. I'm in the North East of the UK, back then I was working in an American Style Sportsbar so the American accent fitted perfectly. I got a few more when the bar got a late license like a nightclub (sadly closed for the last 2 years).
I have since chopped them up into a few extra jingles ;-) Still use a couple of them occasionally.
Thinking of getting some new fresh up to-date ones.
geposted Mon 25 Mar 13 @ 3:58 pm
How To Create DJ Sound With Me
DJ Doms On The Mix
I'am A Dj Of Online Fm And Radio Online Station
DJ Doms On The Mix
geposted Sun 17 Nov 13 @ 3:57 am
synthet1c wrote :
Sorry if you did not understand, basically fruity loops or ableton are programs that you can create music in using software synthesizers and sound samples. You are able to arrange these in virtual sequencers (like drum machines) and arrange your own song, I was suggesting using one of these types of program as you can control many different parameters of your song and add effects. These programs are one of the main ways people produce electronic music, and if you learn the basics it will open up your world to producing songs.
The good thing about these programs is that to start you don't need to know how to play an instrument or any music theory, as long as you can hold a beat (have rhythm) and know what you like in music (which as a dj you should be an expert at).
To start you would need to record a voice sample saying whatever you wish. then you would need to add an effect of a compressor over the whole sample. Compressors basically will squash a waveform (sound) so that the louder noises are made as low as the quiet ones, this seems like it would essentially be quieter, but in reality it makes everything louder for a more dramatic in your face effect, that a listener cannot ignore. An example of this would be a television commercial... Have you ever been watching a movie on television where the volume level feels normal then BAM! an advertisement comes on and blows you out of your chair? this is because the sound has been compressed so there is little range in the volume of the speech.
the second part is saying to use a VST effect, these are basically the same types of effects that are used in Virtual DJ, however, you have more parameters you can change, and your not playing with them live like in Virtual DJ you are sequencing them in your arrangement and are able to listen to over and over again until they sound perfect to you. I only suggested Effectrix because i find it the best for an application like this, but you should know its not cheap to buy, and probably a little difficult if you have never used any music production software before. So i would suggest using the native (built in) effects of whatever program you use as they will do exactly the same job, it will just take a little longer to do. When using effects, your the boss, you put in what suits you as there are no hard and fast rules, play around with them until you find something you like.
I suggested Fruity loops as it was the easiest way for me to get my head around using this type of software and offers instant gratification without having to know anything really, just follow the tutorials and learn the available features. I'm not sure if i can link it here so just google it.
When I said delete it... I meant it! LOL :-D but I play House, Techno, Breaks, Drum n bass, Hip Hop, not r n b or rap/crunk (whatever you call it nowadays)
By exporting it to a WAV (Waveform Audio File) or Mp3 (don't know what that stands for) it means save it so you can play it outside the program in anything that reads those formats eg Virtual DJ.
You can then load the sample you have made into Virtual DJ's sampler simply by going to the sampler browser window, you have 12 sample banks, choose an empty one, then click the small bulls eye and a menu will pop up, select load sample, use the browser to locate the sample you have just made and it will load into the sample bank. Map out a control either keyboard or midi (which ever you have) for the sample to play and you can then trigger the sample with that key anytime you want.
I hope this helps you to create your own sample.
Synthet1c
Synthet1c
Did you really call Hip Hop music and Rap some sh*t you don't play for whatever reason? LOL - http://www.amazon.com/Hip-Hop-America-Nelson-George/dp/0143035150
geposted Sun 14 Sep 14 @ 10:29 pm
It must be a quiet day where you live if your having to respond to a post over four years old... Oooops
geposted Mon 15 Sep 14 @ 10:23 am
I wasn't the first to reply to this thread and didn't notice it was 4 years old. People do it all the time, it doesn't bother me. That said, yes quiet day; no traditional job to go too, no kids, no wife to nag (I don't date Western women, for another thread); getting caught up after being out of town for three days at the Las Vegas DJ Show.
geposted Tue 16 Sep 14 @ 12:55 am
Removed by [Mod Team]
Please read the forum rules
geposted Tue 23 Dec 14 @ 7:43 am
Post from home user moderated.
This topic is not for requests to have someone make you a DJ drop sample. This is not a service that is offered on our website.
If you wish to make your own DJ drop, use a microphone and recording software such as Audacity to record it. Please see the earlier pages of this topic.
Otherwise, if you wish to have a professional DJ drop made (This is not free), search Google for: dj drop
[Old topic closed]
[Old topic closed]
geposted Fri 06 Feb 15 @ 8:31 am
