DN-MC6000 Full Mixer / 4–deck MIDI Controller
![](http://www.denondj.com/Assets/DImages/Products/Images/DNMC6000_4_s.jpg)
Computer Independent 4-Channel, 8 Source Premium Digital Mixer
• Slim Tabletop design for various DJ applications and portability
• Includes 19" rackmount accessory kit for Mobile DJs
• Optimized for Traktor and Virtual DJ users
• Intuitive 4 deck software control, with visible deck color change
• Real-time Matrix Operation, Analog Sources, USB MIDI & USB Audio
• Included USB Audio Interface (Soundcard) 2in/2out (stereo)
• MAC OSX Windows XP/Vista/Win7 Compatible
• New, 3-way Powerful Audio/Video Assignable cross-fader
• Newly designed, high resolution 105mm Touch-Sensitive Jog Wheel
• Smooth 100mm long Pitch Slider with high 14-bit resolution
• Pitch/Fader/Volume Lock function - holds the last known Audio value and position until the NULL point is reached again
• File browse navigation keys & rotary encoder file selector knob w/illuminated ring
• 8 (4 + 4) Hot Cue/Sampler buttons w/dual bank selector key
• Auto Loop Button w/ Beat Jump (Loop Cut)
• Manual Loop In/Out buttons
• Large size Cue & PLAY buttons
• Various EFX control, EFX keys & Parameter knobs
• Various GUI control, Mixer, Video, Scratch, Sampler, REC,
• Powerful Shift Key - used for various dual button operation
• Search Keys (<< >>) to advance around within the file
• Denon's legacy "Pitch Bend" keys
• Vinyl & Pitch Bend Jog modes
• SYNC key for beat matching between decks
• Key Lock on/off button with LED confirmation
• Matrix Input Assignment Selector Knob
• Selectable PFL input gain & program meters
• Independent CUE System (all channels)
• Split Cue function with Cue/Master pan knob
• High quality, high output Headphone Amp
• 45mm Channel & Cross Faders
• Independent Channel A-B Thru Switch (crossfader)
• Cross Fader contour adjustment
• Independent 3-Band Channel EQ w/Kills (High-Mid-Low)
• XLR Balanced & RCA Unbalanced Master Output
• Master Output Stereo/Mono switch
• Booth Output w/Source Selector & level control
• XLR & 1/4 TRS Mic Inputs
• Mic 3-Band EQ (High-Mid-Low) for Mic 1 & 2
• Mic Ducking & Built in Echo Effect for Mic 1 & 2
• Various Utility presets to customize user settings
• MIDI Mappable control surface (Faders, knobs and buttons) for other DJ applications
• Firmware upgradable over USB
• Solid Steel chassis construction
• Kensington lock terminal to prevent theft
• ECO standby mode (green, energy saving)
• AC adaptor powered
DN-SC2000 USB MIDI Controller w/2 Deck Support
![](http://www.denondj.com/Assets/DImages/Products/Images/DNSC2000_2_s.jpg)
• Optimized for Traktor Pro users and supported by Virtual DJ
• Intuitive 2 deck control by single unit, with visable deck color change
• Pitch Lock function - holds the pitch value position until the NULL point is reached when using both layers for control
• File browse navigation buttons & rotary encoder file selector knob w/illuminated ring
• EFX Unit 1 & 2 layer button w/color change LED
• Dry/Wet Parameter encoder knob w/illuminated ring
• 3 EFX Parameter encoder knobs w/illuminated ring
• EFX 1&2 ON/OFF buttons w/color change LEDs
• Utility presets to adjust paired MIDI channels, 1-8 and other items
• USB 2.0 full speed Composite device
• USB bus powered (400mA max), no wall adaptor required
• High Quality Steel Cabinet in a compact size
geposted Mon 16 Aug 10 @ 6:56 am
The MC-6000 looks excellent. After getting burned with AA I bet this will be infinitely better quality.
geposted Mon 16 Aug 10 @ 7:55 am
No price quotes on either of the units yet?? Just curious cause I was gonna put my order in for the VSM4 today but its lookin like I should wait...............
Huey
Huey
geposted Mon 16 Aug 10 @ 8:38 am
Quote :
DN-MC6000 - Included USB Audio Interface (Soundcard) 2in/2out (stereo)
The VMS4 obviously has the addiitonal USB audio channels... So not very future proof in that respect!
Roy
geposted Mon 16 Aug 10 @ 9:36 am
In Germany the price is announced at abou 800,- Euro (~1025,- $).
Greets, Heiko
Greets, Heiko
geposted Mon 16 Aug 10 @ 9:40 am
Just as i said,
Once one company releases the technology they all through there products out there, just takes one to break the ice.
Glad I check these forums every day, cheers
2 mics and echo on each plus 3 band eq, rackmount too. Only thing is, this AC power, guess i answered my own question that i asked a few weeks ago about whether or not all these hybrid's would be Ac'd or not. bummer!
Krad, what's up with the AA device?
geposted Mon 16 Aug 10 @ 9:56 am
Looks interesting?
geposted Mon 16 Aug 10 @ 12:01 pm
Here's a page that has an expandable pic of the unit. I'd get this b4 the AA unit for sure.
http://www.digitaldjtips.com/2010/08/new-denon-dn-mc6000-dj-mixer-midi-controller-announced/
geposted Mon 16 Aug 10 @ 1:23 pm
I returned the VMS4, grinding jogwheel, temperamental play button and dreadful mic quality with serious distortion. It's all down to pricing and expectation and the AA unit is way below my line of quality. For the price the VMS4 is probably ok but the mic distortion is unacceptable. The LEDs are too dull and with USB only are very poor indeed. This Denon should be better.
geposted Mon 16 Aug 10 @ 2:18 pm
Yes, it's all down to our individual standards and what we deem expectable.
Sooner that jeopardise quality I would rather put up with using an external mixer with a midi controller.
I'm not impressed with AA at all and put them in the same category as all the other aftermarket firms, e.g. Soundlab, Kam etc
I am interested to learn how thing have changed over the last 15 years in American as far a manufacturing and quality goes? What companies do you have that make great gear?
I know you have Sabine but what others?
geposted Mon 16 Aug 10 @ 2:52 pm
My mobile rig is Peavey and it's bombproof. I use a Pioneer DJM500 and Denon HC-4500 at the club at the mo and the quality is amazing. An all in one would be a natural evolution but it needs to be wall above what AA can offer.
geposted Mon 16 Aug 10 @ 3:09 pm
Im going to mess around with both plus ill take better close up shots.
geposted Mon 16 Aug 10 @ 5:55 pm
6000 looks great and rack mountable, I am game...
geposted Tue 17 Aug 10 @ 2:20 am
*scores it off the shopping list* no fader start
geposted Tue 17 Aug 10 @ 3:49 am
I read somewhere these controllers will be spread with VirtualDJ LE (into USA) and with Traktor LE (into Europe and Asia).
Why this difference?
geposted Tue 17 Aug 10 @ 6:01 am
I wrote an eMail to the EU Support of Denon (techsupport@d-mpro-eu.com). I think the more request they get as more chances we have to get the product in EU also with VDJ ;-))
Greets, Heiko
Greets, Heiko
geposted Tue 17 Aug 10 @ 6:04 am
Some nice pics on djkit.co.uk http://www.djkit.com/product.php?id=6790&cat=90 if you hover over the top view, you will see the VDJ logo is already placed (with others) on it (right-hand side).
I'm not giving up on the VMS4 just yet though ;-)
Roy
Roy
geposted Tue 17 Aug 10 @ 6:16 am
Yer but Roy,
If you get this one too there will be another logo next to your name ;)
geposted Tue 17 Aug 10 @ 6:19 am
lol... yeah sure, why not. Lend me the £700 please Charlie ;-)
Roy
Roy
geposted Tue 17 Aug 10 @ 9:44 am
For that price you would think it would support the Denon CD drives.
geposted Tue 17 Aug 10 @ 4:25 pm
