Forum: Old versions
Topic: Several (Mixing) problems with V1,05
Hi, I have the next problems/questions
When I am in Smart mixing mode and the BPM differs approx 8 procent, and when the automix starts, then the playing song suddenly goes slower or faster to meet the next song, This I don't like. Virtual DJ shouldn't alter the speed of the playing song, only the new song should match its pitch to the playing song.
When I edit the fade entry on the second page of the BPM editor, and go back to the first page, then the window is'nt closing on OK. I have to change something on the first page first before I can close the window with ok.
Pitch shifting is still not 100%, same bad sound quality as in Atomix
Is it possible to make an indication where you can see if the next automix is going to be an Tempo mix or a fade mix.
Is it possible to move the automix selector from the set page to the front page.
My system is an Atlon 1200 laptop with 512 MB mem and external Extigy soundmodule. Runs great.
Best regards, Djappie
geposted Wed 20 Aug 03 @ 10:37 pm
check your beat lock setting... if it's set to elastic, set it to rigid.
Beatlock is set at "rigid"
Best Regards,
Djappie
