tengo esta laptop asus Intel® Core™ i7-720QM processor
Features 1333MHz system bus, 8MB L2 cache and 1.6GHz processor speed with Turbo Boost up to 2.8GHz.
Intel® Core™ i7 processor
Features 8-way processing for ultimate smart performance. Intel® Turbo Boost Technology delivers extra performance when you need it and increased energy efficiency when you don't.
6GB DDR3 memory
For multitasking power, expandable to 8GB.
Multiformat DVD±RW/CD-RW drive with double-layer support
Records up to 8.5GB of data or 4 hours of video using compatible DVD+R DL and DVD-R DL media.
17.3" LED-LCD high-definition plus widescreen display
With 1600 x 900 resolution showcases movies and games in stunning clarity.
500GB Serial ATA hard drive (7200 rpm)
Offers spacious storage and fast read/write times.
Facial recognition technology
Protects sensitive information.
ATI Mobility Radeon HD 5870 graphics
With 1GB GDDR5 video memory for lush images. HDMI port for connection to an HDTV.
Built-in 1.3MP webcam
Makes it easy to video chat with family and friends.
8-in-1 media reader
Supports Secure Digital, MultiMediaCard, Memory Stick, Memory Stick PRO, Memory Stick Duo, SmartMedia and xD-Picture Card formats.
4 high-speed USB 2.0 ports
For fast digital video, audio and data transfer (PERO SIGO TENIENDO PROBLEMAS CON LOS EFECTOS DE VIDEO CUANDO LOS APLICO) DOY LAS GRACIAS SI ALGUIEN ME PUDIERA AYUDAR SOLO SE FREZEAN LOS VIDEO Y EL AUDIO SIGUE TOCANDO BIEN EL PROBLEMA ES CUANDO METO UN EFECTO DE VIDEO COMO CUADROS O EL CUBO
6GB DDR3 memory
8-in-1 media reader
geposted Fri 01 Oct 10 @ 3:46 pm
Hola,
Te pongo el link a la conversación que ya tuvimos y que Andres (ACW) contesto, no hago quote directo por razones que te seran obvias al leer las respuestas de ACW, pero creo que lo que comento te ayudara a resolver el problema que tienes. Si te sigue dando problemas mandale un mensaje privado, el se pone en contacto contigo en cuanto pueda y te ayuda.
Saludos!!!
http://www.virtualdj.com/forums/134852/Spanish_Forum/VIDEO_SE_CONGELA_AL_MEZCLAR.html?search=ATI%20SVO&page=1
Saludos!!!
geposted Fri 01 Oct 10 @ 11:23 pm
gracias dj svo ya le mande mensaje a dj acw andres esta es la laptop el modelo ASUS G73Jh Intel® Core™ i7 Processor 620M/820QM/720QM : 2.66 GHz - 1.6 GHz, with Turbo Boost up to 3.33/3.06/2.8 GHz; DDR3 1066/1333 MHz up to 8GB (Intel® i7-720QM / i7-820QM platform)
DDR3 1066 MHz up to 4GB (Intel® Core™ i7-620M/ i5 / i3 platform)
Display 17.3" Full HD (1920x1080)/HD+ (1600x900) Color-Shine (Glare-type)
Video Graphics & Memory ATI Mobility™ Radeon® HD 5870, 1G GDDR5 VRAM
Hard Drive Dual SATA support up to 1TB (5400 rpm/ 7200 rpm) para ver como me reconiendas la configuracion del Registry tOOLs
y de nuevo les doy las gracias DJ"S por su gran Ayuda
geposted Mon 04 Oct 10 @ 11:17 am
