sclavel wrote :
Hello,
We just released our new VirtualDJ 7.
As usual, all Pro users gets a free upgrade, no matter how long ago you bought VirtualDJ.
Just head straight to your download center and download it.
You can find general informations about VirtualDJ 7 on the what\'s new page.
Or you can find a more detailed list of the new features on the wiki page.
Also, with the release of version 7 comes a slight change in the product line.
VirtualDJ Home now becomes FREE for non-commercial use.
You can download it for free here.
Enjoy your mixes...
Enjoy your mixes...
VirtualDJ 7.0 (12 October 2010)
Read more about this version HERE
Multi Deck:
-  support for up to 99 decks
 -  include skins for 4 and 6 decks
 -  support both true multi-deck logic or mini-decks with left/right zoom logic
Audio:
-  new Advanced Audio Config panel with line by line configuration
 -  Line-in/Mic support with effects, waveform display, beat-matching
 -  Instant record of Line-in or Mic for replay and scratch
 -  Rewire support
 -  new master tempo engine
 -  new PureScratch engine
 -  low-latency audio on Vista and Win7 when using Advanced Audio Config
 -  new built-in resonant filter on each decks
Database Management:
-  new GenuisDJ algorithm
 -  new FileInfo window with multi-files tag and rename
 -  save to ID3 tags (or mp4 tags) option
 -  new browser fields (composer, rating, custom fields)
 -  support for nested virtual folders
 -  easy drag-n-drop management of virtual/favorite/smart folders
 -  automatically renew and manage Netsearch DRMs before it expires
 -  new zoom mode for temporary fullscreen browser
 -  new integrated audio preview of browsed songs
Video engine:
-  improved H.264 decoder
 -  new overvideo action for multideck configs
 -  access to more than 2Gb of memory on Vista and Win7
Record and Broadcast:
-  Video codec list for video record (on PC)
 -  support for ICECAST2 broadcast
 -  record loopback and mic recording are now set in the Advanced Audio Config
Controllers:
-  Plug-and-play support for more than 80 controllers
 -  support Hot-plug and unplug of controllers automatically
Skin engine:
-  <panel visible=\"VDJScript\">
 -  <element os=\"mac\">, <element os=\"pc\">
 -  <text format=\"\"> can use execution (`) operator (<text format=\"Deck `get leftdeck`\">)
 -  skin engine can parse mathematical expressions in the xml: <pos x=\"42+3*500\" ...>
 -  <init action=\"...\">
 -  <rhythmzone> (like <rhythm> but new simpler syntax based on color values instead of images, see the default 4deck skin for examples)
 -  can have multiple <browser> in panels
 -  can use <center x=\"\" y=\"\"> instead of <pos x=\"\" y=\"\">
 -  improved font replacement on Mac
VDJScript:
-  new action \"get text\" with unix-style execution operator (inverted quote): ` (get text \"The filesize is `get filesize`, playing is `play` and volume is `volume`.\")
 -  new actions \"get loaded_song \'column\' \", \"get browsed_song \'column\' \", \"get automix_song \'column\' \" where column is the name of the browser column (see <columns> in Languages/english.xml for the list)
 -  new/modified actions: \"play_sync\", \"play_onbeat\", \"play_sync_onbeat\"
 -  can use cue names instead of numbers in \"got_cue\", \"set_cue\", etc...
 -  many new actions, see Languages/english.xml for the complete list
Update Ver 7.01
http://www.virtualdj.com/download/updates.html
Kyriws beltiwthikan oi mappers kapoiwn controllers gia na xeirizontai 4 decks.
Prostethikan kai kapoio kainourgioi.
-  fixed left/right for dual-deck controllers on multidecks skins
 -  fix on mac for MIDI controllers with several virtual "ports" (xponent, uc33e, ...)
 -  fixed 4-deck controllers in 2-deck skins
 -  fixed mismatched dual MIDI controllers if VID/PID reported in wrong orders by windows
 -  new registry hack: DisableBuiltinDevices, ScanMIDInoPID
 -  fixed crash if apply-to-all in fileinfo included the separator
 -  fixed VDJScript "page 'effect' ? effect activate" (and other similar scripts) keeps the skin button lit
 -  new VDJScript action "param_cast"
 -  new VDJScript action "get time [elapsed|remain|total|loopin|loopout|cueX] [absolute] [{resolution}]"
 -  new VDJSCript action "deck X get controller_name"
 -  fixed MIDI LED <bar cc="" full="true"> first led was always lit
 -  new MIDI xml <text sysex="" offset="" size=""> will "insert" the text at offset if offset+size>sizeof(sysex)
 -  MIDI xml <text> can use encoding="ascii" to ensure 7-bit midi compatibility.
 -  fixed <text sysex=""> with insert
 -  new controllers DJ2GO, GEMINI16.
 -  modified controllers FFKTLR, MC600, SC2000, SPIN, DJCMK2, DJCMK4, DJCRMX, VCI300
geposted Tue 12 Oct 10 @ 6:08 am
    geposted Tue 12 Oct 10 @ 6:11 am
          xeroume katholou pote tha vgei gia windows?
[apopsis] ti ennoeis ? den einai windows ayto pou bgike ?
geposted Tue 12 Oct 10 @ 6:15 am
          de blepo shortcut gia rename kai anysixo...
    geposted Tue 12 Oct 10 @ 6:32 am
Den yparxei kai min nomizeis oti den se skeftika...
Apla tora kaneis rename kai apo to fileinfo...
Bale shortcut ekei >kane rename >apply ...kai me escape kleineis to parathyro...
Oles oi douleies aytes tora tha ginontai apo ekei..
geposted Tue 12 Oct 10 @ 6:36 am
          Μεγιές μας... :p :)
    geposted Tue 12 Oct 10 @ 7:05 am
          to ekana download sto mac alla grafei akoma 6.1.2 giati???
    geposted Tue 12 Oct 10 @ 7:58 am
          me gia mas kai me tis ugeies mas :D
    geposted Tue 12 Oct 10 @ 8:11 am
An grafei 6.12. ...einai 6.12..
Des an exeis 2 ektelesima programmata,
Sto pc einai virtualdj.exe gia tin v6 kai virtualdj_pro.exe gia tin v7
Den eimai sigouros gia mac.
Genika tha elega antitheta me tin windows version min biasteis para poly na peraseis stin 7 giati exei testaristei ligotero.
Ayto pou exei anaferthei apo kapoious xristes alla oxi olous gia tin mac version einai oti exei ypsilo cpu usage.
Den einai apolyto kai den symbainei se olous opos eipa.
geposted Tue 12 Oct 10 @ 8:17 am
          aplos sto download gia ta windows leei coming soon afou gia ta mac exei vgei.. auto enoo
    geposted Tue 12 Oct 10 @ 9:07 am
          6.1.2. den exei 2 ektelesima progr. kathe fora pou kanw update pataei apo panw.
    geposted Tue 12 Oct 10 @ 9:27 am
          Mas tin eskase to afentiko. Ekane tin ekpliksi kai den ekane release Kyriaki opws synithizei. Kaloriziki kai kales mikseis paidia.
    geposted Tue 12 Oct 10 @ 9:29 am
Gia kapoio periergo logo kata tin egkatastasi den dimiourgei eikonidio VirtualDJ-Pro stin epifaneia ergasias. An exete to idio problima, pigenete sto fakelo ProgramFiles/VirtualDJ kai epilekste to VirtualDJ-Pro kai kante deksi klik Apostoli stin Epifaneia Ergasias (dimiourgia syntomeusis)
geposted Tue 12 Oct 10 @ 9:52 am
          Loipon tha exoume tin eukairia na eksigoume diafora pragmata pou allaksan stin 7.
Thelw omws kapoio feedback apo esas. Kata ti diarkeia tis Beta parousiastike problima se kapoious xristes oti den evlepan ta asteria sto rating. To rating einai ena kainourgio pedio aksiologisis. Loipon kante deksi klik panw se kapoio arxeio. File Infos ... Dwste tou rating 2,3,4,5 oso thelete kai grapste edw, an vlepete ston browser asteria i tetragwnakia me synodeutikes plirofories leitourgiko kai skin.
geposted Tue 12 Oct 10 @ 10:23 am
          skin basic (2 decks)
winxp home eng sp3
blepw tetragwnakia..
    winxp home eng sp3
geposted Tue 12 Oct 10 @ 10:36 am
Το έκανε και σε μένα (XP) κανε unistall το παλιό και μετά βάλε το 7
geposted Tue 12 Oct 10 @ 10:51 am
          Den xreiazetia na kaneis uninstall. Sas eipa einai diaforetiko arxeio, apla mporei na min sas vgalei to eikonidio sto desktop.
    geposted Tue 12 Oct 10 @ 10:56 am
katarxin o filos anaferetai stin mac version.
Ekei an den exei allaksei kati apo tin teleytaia beta, logika kanei overwrite to ektelesimo arxeio (se antithesi me to pc pou dimiourgei neo)
Anyway den eimai o eidikos gia mac kai den exo mac na dokimaso. Prospathise ksana kai an yparxei problima edo eimaste.
Oso gia eikonidio stin epif. ergasias sta xp edo to kanei mia xara,,,... mallon pali kapoio thema tha einai me ta "svista" (bale toulaxiston 7 re dad)
kai ta dikaiomata... h to Uac.
geposted Tue 12 Oct 10 @ 11:08 am
          den xreiazetai na sou thymisw to rito, oti douleuei kala den to peirazeis ! Ta 7 tha perimenoun.
Kai mia kai mou ti les gia ta svista, na sou pw oti egw vlepw asterakia, alla esy ki o Panos me xp vlepete tetragwnaki aakoma..xixixix
geposted Tue 12 Oct 10 @ 11:11 am
          Εγω με Win7 βλέπω.... τον ουρανό... :P
Η μόνη βλακεία είναι οτι έχω τον controller στο μαγαζί και δεν μπορώ να το ευχαριστηθώ... Στις 8:30 που ανοίγει όμως θα γίνει πανικός!!!
geposted Tue 12 Oct 10 @ 11:14 am
