Forum: Greek Forum
Topic: VIRTUAL DJ PRO 7 [Current version 7.05b] - Page: 9
aledjoPRO InfinityMember since 2005
nai alla thes kai alli karta ixou.
geposted Mon 25 Oct 10 @ 5:40 pm
alexmakPRO InfinityMember since 2009
dn mporeis na vgazeis tis 2 exodous apo tin karta ixou tou laptop k tis alles 2 apo ta 2 cdj??
geposted Mon 25 Oct 10 @ 5:45 pm
Na rwthsw kati?Mporw na parw ta Cue Points apo to pc m kai na ta metaferw st laptop m kai genika se ena allo pc...?
geposted Tue 26 Oct 10 @ 8:14 am
Ta cue points opws kai oles oi plirofories pou apothikeuontai apo to software, vriskontai sto root dierectory kathe diskou sou. To arxeio einai to VirtualDJ database (xml)
An loipon valeis ton skliro sou USB disko se kapoio allo laptop i Pc pou exei egkatestimeno to VirtualDJ tha dei to arxeio auto kai tha exeis oles tis plirofories.
geposted Tue 26 Oct 10 @ 10:18 am
Euxaristw gia tn apantisi Dj Dad...Ena arxeio 'Database v5' vlepw ston e3wteriko sklhro mou.Kai vlepw to idio arxeio sta eggrafa mou>Virtual Dj.An egw egatasthsw se ena allo pc to VDJ kai parw tn e3wteriko sklhro mou (an katalava kala) dn xreiazete na kanw tpt...An dn parw tn e3wteriko sklhro mou,kanw antigrafh epikollhsh to arxeio auto sto usb m kai meta 8a to dei t VDJ mono tou h xreiazete na to antigrapsw sta eggrafa m tou allou pc? Sorry paidia alla eimai ligo asxetos apo auta.....Euxaristw!
geposted Tue 26 Oct 10 @ 11:24 am
An antigrapseis mono tin database, tha exei problima. Fysika kai xreiazesaii kai to skliro me ta tragoudia. Twra ...ver 5..xmm den thymamai se poia ekdosi kai meta eginan oi diskoi Hot Plug.. dld me opoio gramma ki an ton dei ton skliro na blepei ta arxeia.
Anyway, to mono pou tha xreiastei, isws, na einai na kaneis Add to Search DB sto PC otan tha tou valeis ton USB skliro.
geposted Tue 26 Oct 10 @ 11:31 am
Ok Dad thnx polu...
geposted Tue 26 Oct 10 @ 11:46 am
apopsis wrote :
aledjo wrote :
de blepo shortcut gia rename kai anysixo...
Den yparxei kai min nomizeis oti den se skeftika...
Apla tora kaneis rename kai apo to fileinfo...
Bale shortcut ekei >kane rename >apply ...kai me escape kleineis to parathyro...
Oles oi douleies aytes tora tha ginontai apo ekei..
exo mia aporia.
to shorcut gia to rename, einai sta sxedia na ginei i aplos to antikatastisane me to file info?
emena pantos de me boleuei katholou to file info giati prepei na kounao to xeri mou sto mouse gia na patiso apply
einai polu spastiko.
apla ithela ena koumpi gia na anoigei to mikro parathyraki tou rename kai me to enter na allaze to onoma kai tautoxrona na ekline kai to parathyro.
tora parapano koumpia kai kiniseis...... bariemai na metonomazo re gamoto!
ESTO tha mporouse otan einai anoixto to parathyro, kai patages to enter, na itan epilegmeno to OK
tora ama patiseis ok paei sto asxeto koumpaki dipla pou de mas ediaferei.
geposted Sat 30 Oct 10 @ 7:35 pm
apopsisdjPRO InfinitySenior staffMember since 2003
Tha symfoniso me ayta pou les gia to "ok" button (to zitisa...) kai ta shortcuts giati kai ego exo tetoia kollimata me to mouse.
Ousiastika epidioko na mporo na doulepso to software xoris katholou mouse /touchpad kai to kataferno sxedon 100%.
Kane to ekseis :
-shortcut gia file info-(se paei apeytheias sto filename - grafeis)
-Alt+A (*) kanei "apply"
-Escape ... kleinei to file info - telos..
(*)opos kai Alt+P =Previous kai Alt+N = Next ...des to _ kato apo ta antoistixa grammata...
geposted Sun 31 Oct 10 @ 4:55 am
aledjo wrote :
exo mia aporia.
Kaneis den kserei ti einai "sta sxedia" na ginei... mono o Theos kai isos ena atomo akoma ..
(stin periptosi mas ayta ta dyo isos taytizontai)
geposted Sun 31 Oct 10 @ 4:57 am
να πω και εγω για την καλη δουλεια που εκανε η ομαδα του προγραμματος μας.επαιξα σαβατο κυρικαη σερι απο 8-10 ωρες συνεχεια χωρις κανενα απο τα γνωστα προβληματα.επιφυλασομαι βεβαια για να παιξω μεριεκς φορες ακομα ωστενα βγαλω κρισιμα συμπερασματα.εν αναμονη,καποιες παρατηρησεις που εχω να κανω ειναι στο search που οταν παω να σβησω αυτο που εχω αναζητησει κολαει για λιγο το Interface,την προακουστικη ακομα δεν εχω μπορεσει να την συνηθησω με το 100% αλλα πιστευω οτι ειναι θεμα χρονου δεν εχω συνηθησει για την ακριβεια το play pause που δεν γινεται ποια με δεξι κλικ αλλα πρπει να παω με το ποντικι κατω στο συμβολακι,και ενα αλλοθεμα που με ψιλοτρομαξε στην αρχη ειναι,μου το ειχε ξανακανει και σε παλαιοτερες εκδοσεις,οταν φορτωνα ενα κομματι στο ενα ντε ενω επαιζε το αλλο μου εκανε beatmach το νεο κομματι που εβαλα χωρις ομως να εχω την αναλογη επιλογη enable απο τις ρυθμισεις.
ξεκολησε απο μονο μετα απο λιγο παιξιμο αλλα φιλαω την πισινη μου ακομα...
αυτα προς το παρων και αναμενω τα επομενα εξαντλητικα τεστ που θα του κανω.
geposted Tue 02 Nov 10 @ 2:27 pm
geposted Wed 03 Nov 10 @ 1:59 am
Na po ki ego kati.
Exei paratirisei kapoios apo esas , ena kapos pio argo ksekinima tou programmatos tou sygkekrimenou , diladi tou 7?
Ennoo otan klikareis stin epifaneia ergasias na anoiksei to programma , kapos san na argei na anoiksei se sigkrisi me tis proigoumenes ekdoseis.
Einai idea mou ? H isxyei?
Yparxei periptosi na ftaiei to skin pou exo epileksei , kai to xrisimopoio omos kai sta 2 p/c , kai se oles tis ekdoseis, kai mexri tora den ypirxe kanena!! provlima?
To ena p/c , exei 17ara wide othoni kai to allo 15ara.
To skin pou exo voleytei einai to palio tis Numark CUE RMX me analiseis , 1280x800 stin 15ara , kai 1440x900 stin 17ara.
Prostheto oti otan paei na anoiksei mou anevainei kapos i CPU , kati pou den ginotane prin kai
episis stis rythmiseis exo tsekarismeno to fast resizing.
Fysika den exei peiraxtei tipote apolitos sta p/c , apo tis proigoumenes ekdoseis mexri kai tora tin 7.
Gia peite mou tin gnomi sas.
geposted Wed 03 Nov 10 @ 6:07 am
Gianni otan ksekinaei se poio simeio vlepeis kathysterisi, otan leei loading database..loading skin. i kapou allou? Amelitaio vevaia kata ti gnwmi mou, alla kouventa na ginetai.
geposted Wed 03 Nov 10 @ 9:13 am
Gianni -> Check ->Clean -> (KAI KYRIOS) FIX database.
To teleytaio kanei kai defrag tin database.
geposted Wed 03 Nov 10 @ 9:35 am
Loipon to kanei molis kaneis klik pano sto eikonidio tou programmatos , opote vgazei to kokkinopo plaisio pleon , kai grafei kato aristera sto plaisio initializing diafora k.l.p. kai afou ta kanei ayta meta anoigei , ekei diakrino mia mikri kathisterisi se sygkrisi me tis palioteres ekdoseis.
Meta pou anoigei to skin den kathisterei toso tha elega , ostoso den arpazei kai amesa opos paliotera.
Mikroleptomereies bebaia , kai isos xoris kapoio provlima , apla to anafero , mipos telika einai provlima , pou den nomizo.
Tin database , panta tin kano chek clean fix.
geposted Thu 04 Nov 10 @ 4:18 am
Γιάννη ναι καθυστερεί περισσότερο σε αυτό το παράθυρο αλλά λογικό είναι... Νέα έκδοση, διαφορετικά πράγματα... Προφανώς χρειάζεται περισσότερο χρόνο για να αρχικοποιήσει όλα τα επιμέρους συστήματα απ' οτι οι παλιότερες εκδόσεις... 99 deck είναι αυτά!!! Φαντάσου να ανοίγεις το power σε 99 cd... :P
geposted Thu 04 Nov 10 @ 4:44 am
Nai ayto skeftika ki ego , apla to anefera pio poly gia na sigourepso oti den einai kapoio provlima.
geposted Thu 04 Nov 10 @ 4:46 am
Αποφάσισα να βάλω και εγώ το 7 στο laptop που έχω για την δουλειά αλλά δεν μου παίζει το δεξί jog από την Rmx (δεν προχωράει το τραγούδι ούτε μπροστά, ούτε πίσω). Έχω τους τελευταίους drivers και αφού έβαλα πάλι την την προηγούμενη version (6.1.2) που δούλευα όλα είναι οκ.
Ξέρει κανείς τι μπορεί να είναι ή θέλει RTFM ?
Ευχαριστώ
geposted Sat 06 Nov 10 @ 11:28 am
dokimase na kaneis reset to factory settings afou prota pareis backup to arxeio mapper an to exeis ftiakseis esy.
se mena pantos paizei mia i rmx me tin 7
geposted Sat 06 Nov 10 @ 11:49 am
23%
