What is GeniusDJ algorithm? How it exactly works and how i can use it? In the user's guide is only this: GeniusDJ – shows recommendations from your own library based on what you are currently playing.
But I can't find any GeniusDJ folder...
geposted Wed 13 Oct 10 @ 3:03 pm
I believe you right click on a song in the browser and it will come up and you select it there.
geposted Wed 13 Oct 10 @ 3:09 pm
right click on the song -> GeniusDJ -> Show recommendations for this folder.... (?) There are songs from netsearch, not "recommendations from my own library based on what I'am currently playing".
geposted Wed 13 Oct 10 @ 3:24 pm
This Genius DJ on my software is no working for some reason.
geposted Sun 12 Dec 10 @ 6:11 am
same here
geposted Fri 08 Apr 11 @ 4:35 pm
my genius dj is not working is there a setting some where that i need to click
geposted Sun 04 Mar 12 @ 11:08 pm
Same here ... Doesntwork!
geposted Thu 22 Mar 12 @ 3:57 pm
Doesn't work for me either, any answers ?
geposted Tue 08 May 12 @ 12:42 am
Nope not working
geposted Thu 25 Jul 13 @ 11:41 pm
Still not working, come on VDJ we paid for this program and it does not work.. Sort it out !!!
geposted Mon 09 Sep 13 @ 8:21 am
Hmmm..... you're a DJ, you shouldn't need some software to pick tracks for you!
geposted Mon 09 Sep 13 @ 9:35 am
Hmm....... I see your point but at the same time it could bring up something I may have forgotten about which could work in the mix...... Think about it.
geposted Mon 09 Sep 13 @ 9:43 am
djdad wrote :
Genius DJ was replaced from Livefeedback, which currently only provides a single recommendation. As we have stated above, the database was reset, as the old one could not be imported to the new feedback system.
The Livefeedback folder will work in a future update and as soon as the database will collect the necessary data.
http://www.virtualdj.com/forums/176410/PC_Version_Technical_Support/Live_Feedback_Does_Not_Work__(.html
That post was of Tue 20 Aug 13.
Meanwhile there was no update as you may know. And most likely there will not be an update until v8.
sclavel wrote :
While VirtualDJ 8 is getting near, we are still committed to bringing new enhancements and fixes to the existing version.
So we are releasing today a new version 7.4.
This will probably be the last of the 7.x series, ...
geposted Tue 10 Sep 13 @ 4:13 am
how do I work genius dj.
geposted Sun 30 Sep 18 @ 10:39 am
