Is there any keyboard shortcut to remove a song from a Virtual Folder? All I see is right-click remove. Delete, Cntrl-Delete, Alt-Delete, Alt-Shift-Delete, etc. all have no effect.
Any ideas?
Any ideas?
geposted Wed 13 Oct 10 @ 10:21 pm
I would also like an answer to this. Another thread suggested File Operations.... Delete, and insisted that it wouldn't delete the file from my hard drive, but that's what it did. I found the file in my recycle bin later.
How can I remove a file just from one virtual folder but have it remain the rest of the folders that it's in?
Thanks!
Thanks!
geposted Wed 14 Sep 11 @ 4:16 pm
There is no keyboard shortcut to remove a song from a virtual folder. However if you choose the virtual folder on the left side of the browser and rightclick on the song that you wish to remove from the virtual folder, the last option is.. Remove.
geposted Fri 16 Sep 11 @ 6:49 am
I\'m not seeing it... Here\'s a screenshot. Am I just being stupid and missing it?
geposted Fri 16 Sep 11 @ 3:15 pm
Err, that image is far too small in this forum. Here's a link: http://i.imgur.com/q7JKo.jpg
geposted Fri 16 Sep 11 @ 3:16 pm
The picture show you want to delete a song.
In the window you are at just click file operations.
There is an option to delete.
If you want to delete a file; then right click on the folder
in the far left side. You will see an option to delete.
geposted Sat 17 Sep 11 @ 9:26 am
christianwheel wrote :
I'm not seeing it... Here's a screenshot. Am I just being stupid and missing it?
Very odd !
geposted Mon 19 Sep 11 @ 7:36 am
Couldn't you use the keyboard mapper or the script and make a key to delete it - just use the learn function
geposted Mon 19 Sep 11 @ 8:35 am
Well the problem is that the REMOVE option doesn't show up at all.
geposted Tue 20 Sep 11 @ 10:51 am
Well the problem is that the REMOVE option doesn\'t show up at all.
To me, both the song as in the virtual folder leaves me delete
geposted Tue 20 Sep 11 @ 4:01 pm
Is it different depending on your computer's software ie mac os vs Windows? Because I'm trying to delete on a mac and having no luck
geposted Fri 29 Dec 17 @ 9:50 pm
