My case in point......
https://virtualdj.com/forums/141864/PC_Version_Technical_Support/why_so_complicated.html
New users (including the OP on this and the above thread), existing users, many are struggling to decipher the mentality behind this ....
The response from from an admin to a new user?
Reply with "Of course no-one is forced to use VDJ 7 - if they don't like changes they can stay with VDJ 6."
Virtual DJ Pro 7 was supposed to be a MAJOR new release, why on earth would I want to go backwards to use such a BASIC function???
Oh and finally, the thread is LOCKED... to a new user..... ummm welcome to the world of Virtual DJ.
geposted Wed 26 Jan 11 @ 12:04 pm
@spc5000: Hey can you tell if Traktor does support m4a files too?
greetings
JoeyTC
greetings
JoeyTC
geposted Mon 28 Feb 11 @ 4:47 am
At least after Version 7.0.3 i dont have the disortion but still if i put the Micro on Deck 4 with for key X - deck 4 linein 'mic' then i can activate the Micro perfect with the key X, do i press X another time the Micro on Deck 4 is off... perfect but then the micro switch up in the topbar TURNS ON .. how can i kick this Micro Switch on the TOP BAR im goin crazy... i try now for months to broadcast with micro nothing works.. grrrrr
geposted Thu 17 Mar 11 @ 2:37 pm
beatbreaker1 wrote :
Its a pretty easy process as you can see and it works well I might add. If you have any questions just hit me up.
Good Luck
Huey
OK this is how I step up a MIC with VDJ7,
Good Luck
Huey
Hello Huey,
I just watched your tutorial above, thanks it may help me I have been using VDj7 in SL and my audience have always told me my voice is too faint, maybe this will help me get the volume up. Cheers, caramia
geposted Wed 02 Jul 14 @ 8:55 pm
