Hi all,
Vdj7 is fantanstic. thanks team. It\'s realy great, even bigger than that.
But...I still have my little screen here so I need the prowser pannel but the browser shows up when a deck is 100% loaded.
Best regards,
John
Best regards,
John
geposted Thu 14 Oct 10 @ 12:47 am
In ver 7 you can have the browser inside a panel and also you can have it inside several panels. However there's still a limitation:
At ALL the times ONE (and only ONE) browser must be visible. You can't show up two browsers, but you can't hide the browser completely too... However you can change it's size and position on screen by using panels ;)
Is that what you're looking for?
geposted Thu 14 Oct 10 @ 1:28 am
Thanks PhantomDeejay,
"you can't hide the browser completely too"
That's it.
best regards,
John
That's it.
best regards,
John
geposted Thu 14 Oct 10 @ 11:37 pm
I think you can. I once tried to make browser 2-5 pixels height and it worked. Try it.
geposted Fri 15 Oct 10 @ 10:27 am
LOL. You can have it visible with "0" dimensions... That's the only way to "Hide" the browser right now...
geposted Mon 18 Oct 10 @ 4:53 am
Hi again,
I think it's time to spent some time for the browser part.
Why do whe have to create a browser in a pannel when whe don't need one....It's stupid!!
It can give errors sometimes when changing skins or min/maximizing. I have some skins that I don't upload because of that.
Also waiting for textboxes something like "textbox format='browser_playlist'". Or I would be very happy if the script can read more lines from the browser than only the selected one.
Hm, hope I made myself clear.
Best regards,
John
Best regards,
John
geposted Sun 02 Jan 11 @ 11:56 pm
Right there with you on the more than one line thing and the browser hidden thing.. Having the same problem with my night ops skin. The browser keeps wanting to re-assert itself over the panel space, even when it's set to be 0 size or off screen. It's annoying. It seems logical that the whole point of putting the browser on a panel in the first place is to be able to hide it completely and swap it out with something else.
DjChuck
DjChuck
geposted Mon 03 Jan 11 @ 12:00 pm
