I want to write/film a walkthrough for DJ techtools on the new version 7 with rewire but the V7 home free is not capable of this.
is there a demo for the full featured version that is available.
geposted Mon 18 Oct 10 @ 10:54 pm
No, I don't think so but it's cheap enough though, why not just buy it?
geposted Tue 19 Oct 10 @ 5:18 am
With home-free version you can use all the advanced features of the pro (including rewire) but they are limited to work for 10 minutes per session.
So if you restart the program you have another 10 min and so on. Basic features are unlocked though.
I don't know if this is ok for you, but i think it is enough time for a test.
geposted Tue 19 Oct 10 @ 6:35 am
@ Charlie Wilson
With all due respect, maybe VDJ doesn't fit our taste. So 325 is a bit far-fetched, when other programs like serato and traktor or only 200 dollars more. (In my city)
@apopsis
Its true. However, a turntablist like me needs to know how the program performs with timecode support, so that we can really test the performance without having doubts.
Just my opinion.
@apopsis
Just my opinion.
geposted Tue 19 Oct 10 @ 6:40 am
DaRealDeal, if you wanna know vdj 7 better and have more time with the features it provides, you will have to buy it. VDJ Home is more for mouse and keyboard and testing, rather than djing
geposted Tue 19 Oct 10 @ 11:18 am
DaRealDeal wrote :
@ Charlie Wilson
To my knowledge, other programs dont offer full editon trials. So how would you know if those programs proform with timecode support? Just my thoughts.
geposted Tue 19 Oct 10 @ 12:28 pm
@ DJ Ton-E 915
The only 3 DJ software on my mind right now is Traktor Pro, Serato ScratchLive, and Virtual DJ. I already know the timecode capabilities of Traktor and Serato and their abilities to replicate real vinyl. Correct me if I'm wrong, but Virtual DJ doesn't have a lot of street rep when it comes to timecode support. That is why I am wondering how I can trial test the timecode support before I purchase it.
geposted Tue 19 Oct 10 @ 2:07 pm
DaRealDeal, go here http://www.virtualdj.com/download/free.html and download the free version (not trial). You will be given 10minutes to test the timecodes.
geposted Tue 19 Oct 10 @ 2:09 pm
I see.. Thank you very much!
geposted Tue 19 Oct 10 @ 2:18 pm
And here is the link for the free timecode for those who want to try with timecode cd's.
http://www.virtualdj.com/products/timecode/cd.html
geposted Tue 19 Oct 10 @ 6:31 pm
I was a little confused, mostly I wanted VDJ under rewire slave, not master, I was launching Live first and then VDJ, I now understand that VDJ is rewire master capable only.
please reverse this and give rewire slave capabilities as this will allow ableton keep all of its vst capabilities.
geposted Wed 20 Oct 10 @ 2:28 pm
As a fellow djtt member i´d like to point out that with 3rd party software its possible to get vdj´s sound back into ableton (smartmixing) . But this is not synced with the midiclock. But with another 3rd party plugin for ableton the incoming sound can be bpm analysed in real time
geposted Wed 20 Oct 10 @ 6:17 pm
VirtualDJ also has VST capabilities :-)
geposted Wed 20 Oct 10 @ 6:30 pm
Can you give more info on this please? ALso does your solution work with macs?
cheers
geposted Mon 01 Nov 10 @ 3:00 pm
Hi, of course i can. This setup is a little bit rough around the edges and i had to try a lot of things to get it to work, but once its done its really cool.
This is called Smartmixing with Ableton, something BentoSan from DJTechtools invented for Traktor and Live 8. It does work on Mac also, but you need a few different programs. I am not sure which programs are needed for mac, i will check back for this. But its totally possible and does only involve freeware.
Teknikalcrysis posted a tutorial here once, it can be found here
http://www.virtualdj.com/forums/123761/General_Discussion/Using_Ableton_WITH_VDJ.html?page=1
please make sure to read all 3 pages, most issues are covered there by SBDJ and fellow forum members, like using JACK rather than Virtual Audio Cable, which isnt freeware. In case the mixer.als isnt provided anymore i can pm it to you.
Basically you grab the audio before its out of the soundcard, send it into ableton, and then send it back into your soundcard and out into the world...
Here´s a practical example of it done by me
Here´s the funny part, now that VDJ is Rewire capable i think its possible to get really creative in scratching terms, layering different scratch´s over eachother... scratching a beat for 8 counts, it gets recorded in Live, loops itself, scratch a melody on top, it all loops itself and so on...
But anyways, i hope i´ve been a help, peace
edit, i forgot to say, you need a plugin for ableton that analyzes the incoming BPM
geposted Mon 01 Nov 10 @ 5:39 pm
