Anybody else think it would be great if vdj had option of enabling a password prompt everytime you use virtual dj?
I have a lil bro who seems to jump on my laptop now and then and seems to muck around with my settings etc. I thought it would we good just to stop any unauthorised users accessing it. Would be ideal for users who install their software on nightclub's pc yeah?
geposted Fri 24 Jun 05 @ 11:51 am
let's misuse a bug
copy your favourite skin and change a fontsize in browser to something big (>18)
if you don't want to use the software change the good skin with the bad.
it will crash vdj on startup. You can make a batch file for this that will swap good and bad skin file in the VDJ directory.
or you can use the exe password protection software for example the freeware: "saveIT"
http://updown.neroes.de/si22.exe
it enables you to password protect an executable.
geposted Fri 24 Jun 05 @ 12:54 pm
geposted Fri 24 Jun 05 @ 12:57 pm
thanks!
geposted Sun 26 Jun 05 @ 12:58 am
