ok so im use the new vdj and when i mix with fast stretch it doesnt sound good so i put it on advance stretch the mix sounds good except for one problem i get a popping noise when i change the speed of the song can anyone help me?
geposted Sun 24 Oct 10 @ 3:23 pm
If you are using version 7 and have this problem that means your computer is not powerful enough or the sound card is not compatible.
geposted Mon 25 Oct 10 @ 2:25 am
Please do not post the same question or message more than once.
You can find answers in your other post: http://www.virtualdj.com/forums/136399/PC_Version_Technical_Support/Advance_Stretching_Problem.html
geposted Mon 25 Oct 10 @ 5:49 am
