Is there a way of adding a graphic EQ in VDJ 7 as I'd like to boost 60hz when not using my subs.
geposted Fri 29 Oct 10 @ 5:23 pm
i assume you are outputting straight to powered speakers ? so no mixer ?
you can find VST plugins that will do this
DJ in Norway turned me on to this one.....Classic Eq by Kjaerhaus , free download
geposted Fri 29 Oct 10 @ 8:04 pm
Yes, the sound is goung through an Alesis PA mixer to powered speakers. My mixer only has bass, mid and treble, and I don't want to lug aroung a seperate eq module, as I have a very neat setup. I was hoping I could have done it in VDJ as using another program means another thing able to crash during a live set. Oh well, another thing for a future update!
geposted Mon 01 Nov 10 @ 7:48 am
This effect already exists for VDJ .... give it a try to see if it meets your needs
http://www.virtualdj.com/addons/542/32-Band_Equaliser.html
Keith
Keith
geposted Mon 01 Nov 10 @ 7:57 am
did you read my post ??
download the plug in and use it , it works great
it's actually an emulation of a tube powered semi parametric
geposted Mon 01 Nov 10 @ 7:58 am
I went to this site, but when trying to get the eq was transferred somewhere else.
Do you have a addr?
geposted Mon 01 Nov 10 @ 12:45 pm
geposted Mon 01 Nov 10 @ 2:53 pm
You gotta be logged in to download it. Dont really want to join something. Cant you zip it up and then upload it somewhere?
Huey
Huey
geposted Mon 01 Nov 10 @ 7:09 pm
i didn't join anything
a couple years ago when i got this it was a different site
yer on yer own , says the preacher in "Blazing Saddles"
geposted Tue 02 Nov 10 @ 9:14 am
So thats a no on the "Zipping" of the program and emailing it then??
Huey
Huey
geposted Tue 02 Nov 10 @ 9:49 am
chucknorrisyouwimps
Yep that's the site I was on.
Thanks for info
Thanks for info
geposted Tue 02 Nov 10 @ 12:00 pm
geposted Tue 02 Nov 10 @ 3:17 pm
